Likes Likes:  20
Thanks Thanks:  3
Results 1 to 15 of 15
Thread: So You Want To Ride 3 Wheels
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Default So You Want To Ride 3 Wheels
    Trikes 101-Basic Rules
    You will hear many riding instructors say, "It's easier to teach people who have never ridden motorcycles, to ride a trike, than to teach people who have ridden 30 or 40 years." This goes against everything we ever learned. Experience, we've been told, is always the best teacher. But not with riding a trike; here the experienced must be untrained from two-wheel thinking, to three-wheel riding.
    First Rule
    Never, ever, put your feet down. There are three wheels, so you won't tip over. But most certainly you can "mouse trap" your feet under the body or rear wheels - not an enjoyable experience.
    Second Rule
    All units have may have a hand brake, just like the one in your car, and you must release it before moving out. Without a kickstand, there's nothing but the hand brake to keep the trike from rolling into Grandma's Corvette.
    Third Rule
    The wheelbase of a trike is generally the same as that of the two-wheeler and may be a little longer depending on the manufacturer, but because of its bodywork, it's slightly longer and a whole lot wider. To determine just how wide, once seated, stretch out your arms -- that's the width you must allow for when cornering.
    Fourth Rule
    A trike involves "direct steering." Point into the direction of travel, lock your outside elbow into the turn, and then roll on the throttle through the turn - this differs from a two-wheeler where you counter steer and lean through a corner. Using the Point, Lock, and Roll system, it's easier to go into, and out of, every type of corner quicker than when riding any comparable two-wheeler. And what's more, with increased confidence from not having to brake or steer around light road debris, such as sand and gravel.
    Fifth Rule
    Look into and ahead of your direction of travel. Good advice, whether on two, three, or four wheels.
    Sixth Rule
    Use both front and rear brakes. On a two-wheeler, your rear brakes are 30 percent of your stopping power. On a trike, though, two rear wheels mean twice the stopping power, so you don't want to override your front wheel. Even in panic stops, the trike stops quickly and keeps straight. Proper braking is very important.
    Seventh Rule
    Practice, Practice, Practice and more Practice.
    Even if you think you are a very skilled experienced rider, a little practice in an empty parking lot performing hard controlled stops and full lock slow speed turns can make the difference. Get to know how your trike performs and get comfortable with its operation.
    Each of these rules are good topics of discussion in future threads.
    Enjoy.
    Jun 2010
    Indianapolis, In.
    Nice write up. excellent info. Just 1 trivial point, your statement: "The wheelbase of a trike is the same as that of the two-wheeler" is just a little off !
    There are some conversions, Hannigan is one, that the wheelbase is actually longer than the original 2 wheel version. This actually makes for a much smoother ride, especially for the passenger!
    Also. adding to your comment on the width: Watch how close you get to the gas pump islands!!!!!!!!!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Dave, Like anything , one still needs the basics
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Good catch and excellent points.
    I have updated the original posting to reflect your wheelbase point.
    I have a CSC Viper kit on my Goldwing and it is definitely longer.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Good post Dave!
    5+ Posts toodawgs's Avatar
    Oct 2018
    Augusta, Kansas, US
    Default Getting Kinda Spooked Here
    I'm new to Trikes after 50+ years of 2-wheelin, just picked up our new Tri-Glide a week ago and you guys are starting to scare me with all these differences in riding trikes over 2-wheelers.
    Quote Originally Posted by toodawgs View Post
    Dont be scared, use a lot of common sense
    If you are a bit shaky practice in a parking lot
    You are going to use upper body strength to move down the road thru the turns
    Exercise will help
    Your good riding 2 wheel skills will be a plus IMO
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Hand brake?
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Find a quiet road or big empty parking lot (on Sunday maybe), climb on, relax, and go at your own pace til you get used to her! Nothing to be scared of - you can’t fall over and you know where the hand and foot brakes are if you think you need them.
    I like the parking lot method ... make tighter and tighter turns ... do it faster and faster until you tip over ... you know ... so you know the trikes limits.
    Just Kidding ...
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Bob, I assume you rode the trike home from the dealer without any difficulty.
    I also assume you probably took the trike for a test ride before purchase.
    If so, how did it feel riding the trike compared to a 2 wheeler?
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Bob, just be careful and don't do anything crazy. You will be fine, trust me.
    Oct 2021
    San Diego, CA USA
    Quote Originally Posted by paws View Post
    I have just reached the 5K miles on my new trike. I love it. I have been riding 2 wheels for a very long time. It different with 3 wheels. Important for you to take it slow at first to get the feel.
    I ride in a group very often. I can keep up with the 2 wheels easily now. Important source of info is your fellow riders. They can give you pointers, experience is key. The more you ride the more comfortable you get.
    Having your shocks and preload set is very important for a comfortable ride. Too stiff and you will bounce all over the place with poor control. Too soft and you will feel like your going to tip over.
    I have never felt like it wants to lift one wheel off the ground. Others say they have and they would have to been going way too fast. The steering is very different than 2 wheels. If you go too fast around the corner you will know it way before it wants to tip. Very scary! Using a little body english helps. Lean into the corner which puts more on the wheel that would want to lift.
    Slow down before the curve staying wide then going to the inside which will give you more room coming out of the curve. The bike has a real positive grip on the road and doesn't slide easily. You can handle most curves faster than the speed limit. But when the curve says 15 miles an hour it means 15 miles a hour. The slow tight curves are the most difficult. Like the man said ride your own ride, take your time, get a good feel for it.
    When your are relaxed when you ride! Your confident and it feels good!! You got it! And it doesn't get better than that! Enjoy and be safe always! It helps if you ride behind another person on s 3 wheeler until you get used to it.
    Oct 2021
    San Diego, CA USA
    Quote Originally Posted by David357 View Post
    I was riding a conversion with 3 wheels in the back and one in front. I took a test ride on the tri-glide! That's was all it took. I bought one! Very expensive! But I love it! Put 5K miles in 2 months.... My wife and I ride most weekends with the club. I ride everyday whenever I get the chance.
    200+ Posts pioneer11's Avatar
    Jun 2016
    Occupied Kingwood Tx
    I got bit by rule 1.
    Cast for 6 weeks and another 6 weeks in a brace.
    Keep your eyes on the road and your feet on the floorboards.2016 Freewheeler
  1. Riding gear on 2 wheels vs 3 wheels
    By Doctoss in forum General Discussion
    Last Post: 10-05-2015, 09:12 AM
  2. want to upgrade wheels and tires
    By OscarV in forum Honda Trikes
    Last Post: 09-01-2015, 12:04 AM
  3. Insurance Premium Same on 2 Wheels or 3 Wheels
    By mgwtrike in forum Honda Trikes
    Last Post: 03-30-2015, 08:25 PM
  4. Wheels forward trike vs standard wheels back trike
    By RTwing in forum Other Brands Trikes
    Last Post: 08-26-2014, 08:42 AM
  5. 2 wheels in front vs 2 wheels in back
    By Doug from Frisco,TX in forum New Member Introductions
    Last Post: 05-06-2013, 01:15 PM
