Likes Likes:  16
Thanks Thanks:  1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 56
Thread: Re gearing a 2016 Harley Trike
  1. #21
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Vin View Post
    Thanks for the reply. They are the same part # and specs. The only problem is that I will have a 32 tooth up front and a 70 rear and the 09 came with a 32 front and 68 tooth rear. The Harley tech said the extra 2 on the back won't allow the belt to fit. I'll probably just get taller tires and another set of wheels for long trips. Easy to swap the rear wheels.
    I'm going to count my rear pulley teeth I have always been told it was a 70 tooth, I will verify today. thanks for the input Fred
  2. #22
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Thanks for the info. I was told I can't go to a 32 since my belt isn't long enough. 31 may work. I believe your trike has a longer belt than my 2016.
    31 will work just fine. Have 30,000 miles on set-up all over this country. Works great NO belt change. Speedometer's are always off from factory a little slow, 3 miles I think. We are always 2 up & fully loaded. Best change I made. Mine is a 2016 also, so I know it works. If no warranty ,put a Power Vision on it & fix speedo & many other things.
  3. #23
    30+ Posts
    Sep 2016
    Tam[a Florida
    Something to consider..... if you lower RPM at a set speed, you will lower torque as well. A 200-300 RPM drop will reduce torque by 5 to 10%. Since torque maintains your speed it may cause a loss of MPG even though a lower RPM is achieved. A reduction of 500-750 rpm (4000 to 3200 or so) would definitely increase longevity of engine nd drivetrain parts.
    But we aren’t pushing s skinny Sportster thru the air.
    The Tri Glide is NOT th most aerodynamic in the HD lineup and consistently gets bad reviews for poor milage. I ride a trike because I want too, Not because I have too. So MPG is not a concern, but passing and staying safe in traffics iS! It is absolutely necessary to ensure my safety and the safety of those around me on the highway that I can maintain the speed of traffic. Torque maintains my speed, not MPG or RPM. But RPM DOES affect torque and performance.
  4. #24
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by Snickers1948 View Post
    That's something I learned after a few months of TG ownership. Keeping the rpm up around 2,700 + actually seems to improve the mpg. But when cruising at 75 mph it gets the rpm a bit higher than I'd like. It just sounds and feels 'busy' and makes the ride less pleasant. But it does work to make me keep my speed down so I guess it's not all bad.
  5. #25
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by ultrafxr View Post
    The first couple of years of the Tri-Glide they were geared the same as the 2 wheel touring bikes. There were a lot of complaints about lack of torque. Subsequent years HD lowered the gearing on the trikes, which is good for most on the Twin Cams.
    What surprises me is that they kept that lower gearing with the M8's. The M8's have better torque, and down lower, than the Twin Cams. I would think going back to the 2 wheeler gearing would work well, or at least half way in-between, like what Bill did.
    One day, I don't know when, I will get an M8 Trike. When I do, changing the gearing will be one of the first things I do.
    www.DKCustom.com
  7. #26
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I think my Freewheeler M8, 107 cu. in., runs great on the highway. That is with a K&N air filter in the stock airbox & a external breather of my own design. If I had known about the DK Custom air cleaner before I got my K&N, I would have got it.
    For some reason, mine seems to run better than most. I was told that again today, after the dealer did the clutch recall fix & rode it a few miles on the highway to run it thru the gears.
    I would think the 114 is even better.
  8. #27
    300+ Posts
    florissant
    What HD really needs to do is put a higher 6th gear in the trikes. Either that or install a 7 speed with a higher gear for the highway. That way you would have the lower gears for taking off and pulling hills and the high gear for highway flying.
    hardheaded
  9. #28
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by headheaded View Post
    I agree. I'd sure like a 7th gear but looking at it from the moco's standpoint there probably are not enough trikes in the sales mix to make it financially feasible.
  10. #29
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    I've known a few guys that have run the Baker 7 speed. Just last week was talking with a guy that's had one in his last 3 bikes....including one in his 2014 Tri Glide.
    They all love them. Lower 1st gear, better spacing between the gears, and 7th is the same as the 2 wheel bikes 6th, without giving up the lower gearing for starting out.
    www.DKCustom.com
  11. #30
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Only one big problem with that though - $,$$$
  12. #31
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yeah! I would have done it years ago if it weren't for the $.
    www.DKCustom.com
  13. #32
    300+ Posts
    florissant
    This seems like it would give us the best of both worlds.
    hardheaded
  14. #33
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yes, that is exactly what Mike was saying the reason he has put it in his last 3 rides. But $3k is a bunch of green!
    I'm happy with the factory gearing on my Twin Cam. When I get the M8, I'll change the gearing a bit higher with the pulley.
    www.DKCustom.com
  15. #34
    20+ Posts
    Apr 2018
    New Port Richey, Fl USA
    Quote Originally Posted by Fearless View Post
    I have run both now 32 sixth gear was useless and 30 seemed pushing the motor at 65-70 range... I purchased Posseriders 30 tooth pulley hoping to get to use sixth gear and can now but... I have to agree with Bill a 31 tooth is great (actually a great improvement) If I ever have old shiney apart again a 31 tooth pulley is going in. I believe I have enough power to make it work on the highway our old 09' doesn't have the higher horsepower of the newer Trikes if you follow what I'm trying to say. From the miles this year out on the long trips at 60-70 MPH a 31 tooth would seem to be a great choice. Andrews pulley's are a little pricey compared to other Manufacturer's but I believe the quality is worth the expense. If you live in a flat plain and never ride the mountains or high elevations a 32 may work. I live in Pennsylvania good luck on your choice of Pulley's it is expensive to switch not like switching mirrors or such just sayin... Travel safe Fred
    PS New Castle Harley Davidson switched mine when my Stator and voltage regulator went south. and the had plenty of adjustment going from 32 to 30 so no reason going to go the other way. good luck Fred
    I will buy a set of p205/75r15 tires with a higher profile and see what that does. Can get 2 for 125.00
  16. #35
    Dec 2013
    Clarion PA USA
    a tire store should be able to tell you what the change in gearing is by tire size just sayin... not sure about going to a 75 series though
  17. DKCustoms postbit
  18. #36
    20+ Posts
    Apr 2018
    You think the 75 series is too tall? I will check with a shop. I figured about 400 rpm off what it is now.
  19. #37
    Dec 2013
    Clarion PA USA
    A good tire shop should have a chart or a program to tell what size goes how far per revolution and speed it changes from one series to the other. For me I am going to try 70 series tires possibly a 195X70 15 if available. If they don't work out my utility trailer will have new tires. Changing tire size is the least expensive way of playing with the gearing.
  20. #38
    20+ Posts
    Apr 2018
    I agree. I will see if their math agrees with mine. Lol. Are you putting on a lift kit also?
  21. #39
    Dec 2013
    Clarion PA USA
    already have a lift on it makes handling so much better gets the mufflers off road and generally looks better . A lift kit is a must for long term comfort Fred
  22. #40
    20+ Posts
    Apr 2018
    Ok. What brand did you get and how much lift did it do? Thanks again.
  1. Re gearing a 2016 Harley Trike
    By Vin in forum New Member Introductions
    Last Post: 09-18-2018, 03:15 PM
  2. Motor Trike gearing
    By Trikerbobbilly in forum General Discussion
    Last Post: 08-06-2014, 09:07 PM
  3. 2007 Trike Gearing
    By hdchaplain in forum Harley Trike Conversions
    Last Post: 10-14-2013, 09:21 PM
  4. Sportster trike oil temp/gearing question
    By GrannyPuckett in forum Harley Trike Conversions
    Last Post: 06-26-2012, 09:47 PM
