Results 1 to 16 of 16
Thread: Tri glide width
    Minnetonka MN
    Default Tri glide width
    I have seen the specs for the overall width of the 2011 tri glide listed at 43.9" and 54.7". What gives? Is one measurement the track?
    What is the track of the tri glide?
    600+ Posts TNTriker's Avatar
    May 2010
    McDonald, TN. USA
    Default Re: Tri glide width
    A search on Google found this:Chassis and Dimensions
    Brakes: 4 piston fixed front, 31.75mm single piston floating rear
    Parking Brake: Lever actuated dual parking brake.
    Lean Angle (per SAEJ1168): N/A
    Exhaust System: Chrome, cross-over exhaust with dual mufflers and taper end caps.
    Front Wheel: Black 7-Spoke Cast Aluminum
    Rear WheeL Black 7-Spoke Cast Aluminum
    Wheel Option: N/A
    Front Tire: MT90B16 72H
    Rear Tire: P205/65R15
    Length: 105.80 in.
    Seat Height: 27.50 in. (laden) / 29.60 in. (unladen)
    Ground Clearance: 4.70 in.
    Rake Steering Head/Trail: 26° / 3.94 in.
    Wheelbase: 66.65 in
    Track Width: 43.88 in.
    Fuel Capacity: 6.00 gal.
    Oil Capacity: 4.00 qt.
    Dry Weight: 1139.60 lbs.
    Running Order: 1174.20 lbs
    Luggage Capacity: 6.56 cu ft. (volume) / 80.00 lbs. (weight)
    Quote Originally Posted by swodo View Post
    I just measured my Tri [11] I don't if I'm measuring from the same spot that the factory measures, But from the outside of one tire to the outside of the other [not the fenders] i get 50 inches???
    May 2010
    McDonald, TN. USA
    I don't know stuff, but I have common sense. You guys are making something hard out of something so very easy. I would suspect the track is measured from the center of each tire. So take your 50" and substract approximately 3" from each tire, that would leave 44". Now If I knew how to use a caliper, I could come pretty close to the 43.88 that Harley shows as the track. Hope this helps.
    1500+ Posts
    Sep 2009
    North East Ohio
    Quote Originally Posted by TNTriker View Post
    You are spot on.
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    You should know guys need humored, we like to use tools and sometimes take the long way around the problem, gives us more time to drink beer while solving the worlds issues.
    750+ Posts
    May 2011
    peru,in,usa
    will my '09 t/g just barely fits my car dolly. good enough
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    You just spoiled a half days WORK in the shop.
    May 2010
    McDonald, TN. USA
    Quote Originally Posted by Lucky View Post
    It's Friday the 13th. I just saved you from possible injury while fumbling around in your garage!
  11. #10
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    I just went into the garage and measured the '09 and '11. They are 54 3/4" wide. Too wide to split lanes, ride on the side walk, or gutter run traffic.... all the fun stuff you used to do on 2 wheels. I would guess width should be overall width, not tire width, or axle width. Wife and I can still park both scoots in 1 parking space, just not side by side anymore. They still draw a crowd, just not sure if it is the trikes, or my wife's 60 year old great [s]ass[/s] ah looks. One thing for sure, they may be twice as wide, but they are 3 times the fun..... especially when you are old and now you don't have to worry about falling over.
    Oops, guess HTML doesn't work here
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
  12. #11
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Quote Originally Posted by msocko3 View Post
    I'm so glad you explained that, Mike! It clears up so much about what goes on at my house..........
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
  13. #12
    150+ Posts Frang's Avatar
    Massachsetts.,USA
    That's no way to describe your wife's butt-twice as wide.lol
  14. #13
    Jun 2010
    Coram, NY USA
    I've mesured it and then forgotten the number. I do know my TG just fits my 5x10 trailer with about 2" on either side.
  15. #14
    2000+ Posts Blondie Gal's Avatar
    Mar 2010
    Killeen / Fort Hood, TX
    Gee, I didn't realize our GW1800 CSC was that much bigger than a TG - ours fits into our 7 x 16 trailer with maybe 4" on each side!
  16. #15
    1500+ Posts
    Sep 2009
    North East Ohio
    We are all indebted to you.
  17. DKCustoms postbit
  18. #16
    Sep 2009
    NE Ohio
    Quote Originally Posted by Nana View Post
    Always willing to help.
  1. street glide trike rear fender width?
    By Qatar_TG in forum Harley Trike Conversions
    Last Post: 02-18-2013, 10:38 AM
  2. tri-glide track width
    By dyna_rider98 in forum Harley Tri Glide
    Last Post: 05-29-2012, 06:50 PM
  3. Axle width
    By swodo in forum Harley Trike Conversions
    Last Post: 12-30-2011, 11:49 AM
  4. Frankenstein width
    By swodo in forum Frankenstein
    Last Post: 12-20-2011, 12:59 PM
  5. Tire width
    By PhilGilbert in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-21-2010, 10:27 AM
