LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  8
Results 1 to 19 of 19
Thread: 2009 stallion
    Feb 2017
    Palm Bay Florida
    Default 2009 stallion
    i hit a manhole really hard and the front light assembly broke off the hood. looks like i need a new hood and light assembly. is there anything i can do to fix it
    250+ Posts
    Dec 2010
    oly,wa
    Good luck
    this same thing happened to Terry at the trike rally in deadwood. it looked like the screws holding the mount in place were tightened too tight and finally just broke off. I did not hear what he had to do to get it fixed. maybe fiberglass it permanent.
    Dragon
    100+ Posts Las Vegas Biker's Avatar
    Dec 2010
    Las Vegas, Nv USA
    Default headlight
    Hi,
    As Dragon said, Ive had the same thing happen to me, Twice. Both times I ended up with getting a replacement housing from Texas. Takes awhile to get it but that's the way it goes. Tried several shops to get it fixed but no luck. Both times were the result of very bad potholes, once in Alaska and the last time in south Dakota. Good luck with yours. Terry
    Sep 2016
    Kent, washington, USA
    Default Head light
    I repaired mine with epoxy then build around the post to reinforce. I had to remove the hood which is easy. With hood open remove the mirrors then unplug the head light, remove the Phillip's head screws that attaches the skin except the ones at the very front, close the hood then remove the screws at the very front, then the hood slides off. I hope this helps. #697
    Feb 2017
    Palm Bay Florida
    Default stallion 2009
    can i still get a replacement houseing in texas. how about a headlight assembly
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    Quote Originally Posted by danny gallaher View Post
    You could contact Motor Trike HQ in Troup, Texas. They have a website for contact info.
    Feb 2017
    Palm Bay Florida
    Default stallion trike
    i live in titusville florida. does anyone know where i can get my stallion worked on. i found the parts for it and need some one to put them on.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    I live in Titusville, send me a PM with your phone number and maybe I can help you.
    Tomg
    Feb 2017
    Palm Bay Florida
    thank you TOMG. dont know what a pm is but here is my # 402-617-9025
    300+ Posts
    Signal Mountain Tn
    In the world of the internet a PM is a "Private Message".
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Quote Originally Posted by tomg View Post
    Tomg
    Way to step up Tomg, it's people like you that makes this site what it is.
    Tom his "09" maybe a fiberglass body. Still I think the best ave of attach is to remove the hood makes things easier to work on. Then I would guess epoxy or fiber glass the new assembly in place. Call me if you think I can help.
    Oct 2009
    Titusville, Florida
    Thanks Ted, I spoke with Danny yesterday and I will be getting together with him to see what he has. He said a new painted hood has been ordered along with the headlight assembly.
    Tom
    Copy that Tom
    Feb 2017
    Palm Bay Florida
    Default Danny
    Does anyone know where i can get a sony controller for the dash in my stallion
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Might try eBay or amazon or Sony. Search for item using model # and /or serial #.
    Danny I did a quick look yesterday but could not find the one I removed. I will look again today and let you know.
    300+ Posts
    Signal Mountain Tn
    Here is a link to replace the whole dash unit. I think it does away with the unit in the trunk.
    https://www.ebay.com/itm/PLMR91US-Si...item23548aa5df
  19. #19
    still can not locate my part
    i also used one like above in my wifes stallion
  1. Calling all 2009 Stallion owners (or previous 2009 owners)
    By TnTrikeRider in forum Stallion Trikes
    Last Post: 12-24-2015, 06:18 PM
  2. For Sale 2009 Stallion
    By Art576 in forum Stallion Trikes
    Last Post: 06-03-2014, 09:22 PM
  3. Luker now Owns 2009 Stallion
    By Lunchbox1983 in forum Stallion Trikes
    Last Post: 05-30-2009, 10:52 PM
