Likes Likes:  26
Thanks Thanks:  2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 52
Thread: Freewheeler Lid Organizer - accessory I would like to Have
  1. #21
    100+ Posts FLRT's Avatar
    Oct 2014
    Illinois
    I want a beverage warmer/cooler and a nut massager...
    I like that lid organizer, just have to be careful not to drop the lid and have the stuff in the organizer get smashed/broken if coming into contact with full trunk!
    2015 H-D Freewheeler - Superior Blue
    2014 Honda CB1100 - Candy Glory Red
    1976 Honda CB750 K6 - Candy Antares Red
  2. #22
    100+ Posts Red59's Avatar
    Apr 2014
    Walled Lake, MI US
    Quote Originally Posted by FLRT View Post
    and a nut massager...!
    Isn't that what the ole lady is for when riding two up?
  3. #23
    Quote Originally Posted by Red59 View Post
    <--- won't touch that with 2 ten foot poles
  4. #24
    100+ Posts
    Nov 2011
    kernersville NC. USA
    Default organizer for freewheeler
    Check with Bob Schoonover.
  5. #25
    20+ Posts
    Apr 2015
    SFV, CA USA
    Followup on Saddleman (Part# 3516-0151), as mentioned back on 4/8 did install it on my freewheeler and my wife's Tri, cleaned all surfaces, applied tape with temperature in the low 70's low humidity, didn't attached pouch until after 48 hours to let glue set, etc etc. Both worked great until just recently, several rides with temps near 100 and over, and higher then normal humidity for CA. A week ago opened wife trunk at start of another trip to have it fall off, then 2nd day into the trip same thing happened to mine. Occurring within 3 months of install not good.
    Both are sitting on the shelf, while reviewing non glue methods (and other vendor options) for storage of small items on both bikes, less of an issue on the tri with the top trunk.
    Hope others have better results then we did.
  6. #26
    900+ Posts
    Bellville, Texas, USA
    My organizer did the same thing. Where I live is pretty hot and the second day mine fell off. After it fell off a couple of times I replaced the Velcro with some super industrial strength Velcro I bought at Walmart and for four months now it has stayed on.
    Sunman
  7. #27
    Gone But Never Forgotten dirtdobber's Avatar
    Jul 2011
    sand mountain, AL
    I usually use gorlia glue with the loop fasteners. Never had a problem. The red 3m double sided tape will also work. Add pressure to keep it secure and let it cure over night. Heat helps for it to stay stuck good.
    I have kuryakyn on my street glide it is too wide to fit.
    http://i25.photobucket.com/albums/c5...an_cross_f.jpg
    20015 freewheeler
    2005 113 pro twin super glide
    2010 ss106 wide glide
    2004 1800 VTX custom
    2012 GW RS
  8. #28
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Quote Originally Posted by cagless View Post
    I know this is an old thread .... but just wanted to say that if you have a trunk rack the rack bolts would hold this in place if the organizer could be drilled in the bolt locations and you used some large fender washers.
    Bob
  9. #29
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I bought industrial strength Velcro for mine, but the organizer wouldn't stick to it until Jerry AKA Gold Rush stitched the outer edges of the organizer to the Velcro. He used a tiny drill bit with a Dremel tool to make holes then used an upholstery needle and nylon thread, which I believe was fishing line.
    It has stayed in place and is very handy.
  10. #30
    Apr 2017
    Kansas City, KS
    Pic of mounted bag
    I have a luggage rack on my Freewheeler. I got this Saddleman organizer and I will have to punch holes in corners where the bolts hold the luggage rack on, but should hold the organizer on securely I also got the pair of trunk liners. They fit in great.
  11. #31
    4250+ Posts
    Feb 2015
    San Antonio
    I also have the Saddleman trunk liners which I really like. The organizer is super handy for my small must have items. I am sure you will really enjoy having both of them.
    Ride safe and have fun.
    Lola
  12. #32
    I have messed with making one out of a plastic tray, A drop in metal one would be better IMO
  13. #33
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    I realize this is an old thread but it helped me with my purchase and installation of one of these trunk lid organizers.
    I did replace the Velcro with a much stronger 3M very high bond dual lock tape.
    It holds everything in place very securely.
    Like others the fit is tight but as you can see in the attached photo it will fit.
    Hopefully this helps someone who may also be thinking of buying one of these.
    2008 Stallion
    Reading, PA 19606
  14. #34
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Is the back of that organizer hard plastic?
  15. #35
    Nov 2016
    Reading, PA
    Quote Originally Posted by JTJersey View Post
    No. It was more like a hard fiberboard. It is not rigid and flexes easily.
    2008 Stallion
    Reading, PA 19606
  16. #36
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by W3JNP View Post
    And that 3M tape holds to it? That's good stuff, I use it to hold the GPS on my gas tank, but it generally doesn't hold well to fibrous materials.
  17. #37
    4250+ Posts
    Feb 2015
    San Antonio
    I used that tape, just tacked it to the organizer in a few places with fishing line and a needle. I used a tiny drill bit with a Dremel to punch holes. When I took it out of my 2015 FLRT I used new tape on the lid of my 2020, didn't have to replace any of the tape on the back of the organizer.
  18. #38
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by LadyonaMission View Post
    Brilliant! I'm sold. I'll be getting one of these this afternoon. Thanks.
  19. #39
    4250+ Posts
    Feb 2015
    San Antonio
    I also cut out a place for the retention cord with several stitches along that area and stitches on the binding at the cuts.
  20. #40
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Now that's professional. Very nice detail.
  1. Freewheeler Gas Mileage
    By Sunman in forum Harley Freewheeler / Road Glide 3
    Last Post: 12-18-2014, 12:29 PM
  2. New shift accessory
    By Pup in forum Harley Trike Conversions
    Last Post: 10-27-2013, 09:41 PM
  3. 2012 Tri-Glide accessory plug
    By Miker1358 in forum Accessories
    Last Post: 07-02-2012, 09:29 PM
  4. accessory outlet
    By geraldlanc in forum General Discussion
    Last Post: 03-19-2012, 11:46 AM
