Results 1 to 4 of 4
Thread: 2008 stallion headlight adjustments?
    100+ Posts
    Sep 2017
    Clinton Township Michigan usa
    Default 2008 stallion headlight adjustments?
    Hello,
    I know I can adjust the entire assembly through the 3 mountings but is there any way to adjust the 2 lights individually? I have converted the lights over to leds and love the brightness but now the low beam seams to be extra low in how it is being directed but the high beam seems to be correct and I don't want to raise it any more.
    Thanks for anyone help.
    Greg
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by Greg336 View Post
    Hello,
    Greg
    Greg, what kind of LED's did you find that work. I tried several in the projector lenses and gave up when I read that LED's don't work very well in projectors. I have HID's and they work great. Rick
    Stallion #378
    Suzuki Burgman 650
    the only adjustment is the whole assembly
    100+ Posts
    Sep 2017
    Quote Originally Posted by rocket1lf View Post
    Sorry for the delay, I don't get here to often. I'm listing the LED's below. They work pretty good but I also replaced the side fog lights with LED's to make it even better. I won't say it's a 100% improvement over the stock lights but I would say I have given myself at least a 80% improvement over the stock lights. Much brighter and of course more on the white side instead of the yellowish light the stock lights put out.
    My biggest problem is the Low beam is to low and the High Beam is just right so that is why I'm here trying to figure out how to raise the low beam and keep the High Beam where it's at or lower the High Beam and raise up the entire assembly. If I can figure out how to do either of these it would be Great.
    Main replacements from amazon,
    Auxbeam LED headlights F-S3 Series H8/H9/H11 LED Headlight Bulbs with 2 Pcs of H11 Headlight Bulbs 72w 8000LM CSP Chips fog Lights
    Fog Lights from wish.com,
    2pcs 2.7 inch 40w Round Small fog Lights Combo Beam Led Pods Lights for Motorcycle, Offroad Trucks, Suv, Atv, Utv and Boats.
  1. 2008 GL1800 headlight adjustment with R/S
    By camplejeune in forum Roadsmith Trikes
    Owners Forum
    Last Post: 10-01-2022, 06:54 AM
  2. HeimJoint adjustments
    By Jimsjinx in forum Honda Trikes
    Last Post: 04-26-2022, 06:45 PM
  3. Headlight/aux/foglight adjustments
    By Trikesyke in forum Harley Tri Glide
    Last Post: 03-29-2017, 08:43 PM
  4. Headlight on headlight off
    By dano2005 in forum Honda Trikes
    Last Post: 07-08-2012, 07:00 AM
  5. Aero 750 Motor Trike Suspension Adjustments
    By skuuter in forum Motor Trike
    Last Post: 07-31-2010, 10:01 PM
