Likes Likes:  4
Results 1 to 11 of 11
Thread: mighty mike
    80+ Posts
    Aug 2020
    zeeland, michigan 49464
    Default mighty mike
    Has anyone used a A1 Vented Dip Stick and if so how do you like it?
    I have a 2017 M8 and wonder if it is the right way to go for a sumping issue.
    Thanks for your time.
    Quote Originally Posted by mighty mike View Post
    Have you had the vent installed on the primary...?....
    Bob, that will not help the engine oil sumping problem
    The 17 model year engines had the first generation oil pump ( new and improved designs had a lip seal) and improved oil pump to help the problem
    Not all engines showed this problem, same goes for the tranny fluid transfer issue, some did , many did not
    80+ Posts
    Aug 2020
    Default mighty mike
    To Bob no the primary is not vented. Bought bike new. All stock.
    Mike, if your 17 is sumping have you tried running your engine oil only 1/2 up the stick?
    Also let the engine idle for at least a minute before shutting down
    While there are many good reviews on the vented dip stick IMO it is only a band aid
    The real deal would be the updated oil pump with the seal IMO
    If I’m not mistaken there was a service bulletin on the vent and your Dealer will put it on..
    Here is the link to the bulletin
    https://static.nhtsa.gov/odi/tsbs/20...65612-0001.pdf
    Mike, here is a link to the kit instructions in case the dealer will not warranty the job
    https://serviceinfo.harley-davidson....0_en_US.blaise
    80+ Posts
    Aug 2020
    Default mighty mike
    Thanks to everybody who replied. I was concerned about the oil from the crank case of the engine getting
    into the throttle body, not transmission fluid into the primary case. Does a vented oil dip stick relieve the
    built up pressure from the crank case and if so does that help eliminate oil getting into the throttle body
    from the breather bolts on the cylinder heads? If anyone has tried the vented dip stick how is it working
    for you.
    Have a Merry Christmas everybody.
    for you.
    Too much oil in the crankcase usually is the problem ...The oil level on the dipstick should be 3/4 of the way....Not right on the full line....Oil will seek its own level, Especially at high RPM's...
    80+ Posts
    Aug 2020
    Default mighty mike
    Thanks for the info, I will lower the oil level in the crank case. I checked and it was above the full
    mark. Had the oil changed in all 3 holes late this fall just before putting it into winter storage at the
    local Harley dealer where I bought it. It's hard to get good help these days. Maybe I'll start doing
    my own oil changed again like when I had the 2 wheeler. Hey I am not lazy but being 73 I just don't
    care about laying on the garage floor any more.
    Stay safe everybody.
    If you are sumping you can pull the crank sensor out and measure the oil that comes out
    Any more than 6oz of oil the MoCo says is a sumping engine and needs attention.
    I dunno for sure if the vented stick works on all cases that sump, it is hit and miss and kinda spendy IMO
    Keeping your oil level down to the 1/ mark will help, as well as letting the engine idle down for 1-2 minutes after a ride helps some
    The real cure is the updated oil pump with seal
  1. Mighty Mike
    By mighty mike in forum New Member Introductions
    Last Post: 08-28-2020, 10:09 AM
  2. Replies: 25
    Last Post: 09-08-2019, 04:06 PM
  3. "Mighty Mo"- History At Its Finest Hours
    By David357 in forum General Discussion
    Last Post: 05-13-2017, 10:10 AM
  4. About to install Mighty Mites
    By Fearless in forum Harley Tri Glide
    Last Post: 04-09-2017, 09:18 PM
Tags for this Thread
