Likes Likes:  8
Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: New leg
  1. #21
    300+ Posts roadking2's Avatar
    Oct 2013
    North Lawrence, Ohio
    Give ya lots of credit buddy. Maybe heel and toe set up would help. After downing into first, just kick it gently on the heal side. Just trying to help. Can't imagine what's it like with a prosthesis . Practice, practice, and more practice. You can do it
    Heel and toe is what works for me. No mods or extra $$$$ required and it gets the job done. I lift my leg slightly and drop it on either the heel or toe peg and away I go. I did get longer shifter pegs and that helps. I don't have to be as accurate with my leg drop as I need to be with "standard" pegs. The additional fraction of an inch in length made a big difference for me anyways. Sometimes it takes me a try or two to get it into neutral, but on the move up shifting or downshifting is pretty easy. Neutral is sort of half way between gears and sometimes my leg drop is a bit to heavy and before you know it, I'm back in first gear.
  2. #22
    40+ Posts
    Feb 2016
    Des Plaines, IL USA
    Quote Originally Posted by roadking2 View Post
    Thanks, great input!
  3. #23
    60+ Posts
    Apr 2013
    Bedford, TX
    Maybe heel and toe set up would help. ... Can't imagine what's it like with a prosthesis.
    While I could clumsily lift my prosthetic and hit the heel / toe shifter, there was always some apprehension particularly if I had to do it quickly in traffic. I installed a Widowmaker tank shift kit and for me, it works very well.
  4. #24
    Oct 2013
    Quote Originally Posted by Dennis Murawski View Post
    If I had to shift quickly especially in traffic, I'd be more worried about taking my hand off the grips than I would be worried about missing a shift with my foot/leg. Glad your widowmaker works for you, but there is nothing clumsy about the way I lift and drop my foot using the heel/toe. I guess it's easier for me to manipulate my prosthesis than it is for you to manipulate yours. We each have to find our own way. Neither of us uses a Pingle or a Klicktronic, so it's good to see we at least have several options and one of them hopefully can satisfy our needs so we can ride on.
  5. #25
    300+ Posts
    florissant
    do you still have your knee ? i don't and shifting was just to hard trying to use my leg. i just extended the shifter straight up and reach over and shift it. the widow maker would be my next choice. i wanted to shift it on my own, that's why i went with this setup. we do each find our own way to do things.
    hardheaded
