Likes Likes:  20
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: Extended Floorboards
  1. #21
    Quote Originally Posted by WindyOne View Post
    Still working on this. I got my tap, fixed the threaded holes and got the right side installed.
    Before I would use the bolts in the kit, I ordered stainless bolts for the left side. I should have them early next week and will hopefully finish up what should have been a simple job.
    Not to make lite of it, Sometimes stuff happened's'....Hopefully the worst is over.....
  2. #22
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    Done,Done, and Done.
    Funny that the left side, the one I was the most concerned about was the easiest side to do.
    1" sure does make a difference though in comfort.
  3. #23
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I am so happy for you.
  4. #24
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Thumbs up
    Done,Done, and Done....
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  5. #25
    Quote Originally Posted by ShapeShifter View Post
    Wow, that brings back some memories ... when I was doing Nuclear Repair, my boss, the Admiral insisted, I call the second we finished a job .... I was always on the 1900-0700 shift, that's when all the work got done because there was no Looky Loos. Anyway, when I would sign for the completion, I would call the admiral, usually around 0300 ... even if the job finished around 2300 (took me awhile to review all the paperwork, dad always said, "the job isn't done until the paperwork was."), and play him a recording of that ... got to where he would listen to about as much of the song as is played in that clip and hang up. He finally told me I could just tell him in the morning ...
  6. #26
    Jan 2020
    KENNESAW
    Default Primary oil change with extended floorboards
    This is just some information.
    A week ago I installed the extended floorboard kit from DK Customs. Yes I encountered the "difficult to remove" bolts as others have mentioned although apparently not as difficult as others have encountered.
    This weekend I did a 3 hole oil change. I noticed the parking brake cable now runs directly under the drain plug on the primary case. There is enough slack in the cable to move it aside a bit for getting a socket on the plug for removal but not enough slack to get the cable cleanly out of the path of the draining oil. I let the oil dribble over the parking brake cable and cleaned it afterward.
  1. Extended extended warranty
    By rwhgme in forum Harley Tri Glide
    Last Post: 02-24-2016, 08:04 PM
  2. HEEL/TOE SHIFTER & floorboards
    By Chief in forum Accessories
    Last Post: 07-08-2011, 10:15 AM
  3. CSC Volusia Softail and passenger floorboards
    By CadtoChrome in forum California Sidecar Trikes
    Owners Forum
    Last Post: 11-21-2010, 12:21 AM
  4. Rune trike w/fairing,floorboards,and flames
    By JJTRIKER in forum Honda Trikes
    Last Post: 08-20-2010, 02:25 PM
  5. Floorboards on CSC trike
    By Scalp Hunter in forum California Sidecar Trikes
    Owners Forum
    Last Post: 06-25-2010, 10:40 PM
