Likes Likes:  1
Results 1 to 6 of 6
Thread: Light upgrade RSV
    May 2016
    Perkins, OK USA
    Default Light upgrade RSV
    I need some help and input. I will be posting this in several groups to gain maximum information. I am adding passing lights to my RSV.
    Has anyone used a lightbar other than the Yamaha bar?
    Does anyone have a lightbar they would part with?
    Has anyone used LED lights?
    Has anyone converted to LED headlight?
    Best LEDs to use for this upgrade?
    Thanks for the help
    20+ Posts
    Nov 2015
    Reading
    Quote Originally Posted by Livinon3 View Post
    Thanks for the help
    Hi, If you pose the same question in Ventureriders forum you may get alot more answers. I mean no disrespect to this forum, just that there are alot more RSV owners on there and they have the answers to the questions you are asking.
    I can only add I have the Yamaha lite bar on both my RSV be sure to use a relay when wiring them, to take the load off the ign switch. There is a spacer avail. to move the lite bar away from your fairing to make access easier for outer fairing removal.
    Good Luck, Craig
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    venturerider.org
    great site..
    750+ Posts
    Jan 2010
    east windsor ct
    i changed the head light to a truck lite
    7" 27270C Round LED Headlight
    about $180 worth every penny... and did away w the passing lights...
    your results may vary
    60+ Posts adventurer 08's Avatar
    Aug 2013
    Mayville Mi
    I am also a member of Venturerider.org, this is a great group of people that know there stuff when it comes to 1st and 2nd gen. Ventures. Weather you have a question on lites or a bolt size someone been there and all ready done that. I have bought my led lites from Superbrite LED lights, they carry everything you would want.
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    When I had my 09 I put a HID bulb in place of the stock light. No need for passing lights after that. I did have passing lights on my previous 05.
  1. Engine Upgrade
    By pddgm in forum Harley Trike Conversions
    Last Post: 12-23-2015, 10:30 AM
  2. Help with performance upgrade
    By GARYD in forum Harley Tri Glide
    Last Post: 10-05-2015, 02:39 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
