Likes Likes:  4
Results 1 to 5 of 5
Thread: Changing spark plugs on Stallion
    20+ Posts
    Sep 2017
    Rushville, Indiana, USA
    Default Changing spark plugs on Stallion
    This morning I was able to talk with my mechanic regarding changing the spark plugs on a Stallion Trike. His instructions were to unbolt the cruise control servo and move it to the side. Then remove the ignition coil completely. In order to reach the back one you will need a long universal spark plug socket. You can get the other three with a three inch extension.
    He found on mine that there is a cylinder head temperature sensor that is located between cylinders two and three, and there is a rubber seal that goes around the wiring harness that goes to the temp. sensor and my plug was not in place and it was letting water gather in the valley where the spark plugs are located.
    This water was allowed to sit there and rust the plugs to the cylinder head. He either replaced the rubber plug or just put the one that was there back in place and I should not have any water issues around the plugs from now on. The engine runs as smooth as silk after the plug replacement.
    I hope this is helpful to those of you who asked for the above information.
    Good job Jerry Thank you
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Quote Originally Posted by JerryC View Post
    This morning I was able to talk with my mechanic regarding changing the spark plugs on a Stallion Trike. His instructions were to unbolt the cruise control servo and move it to the side. Then remove the ignition coil completely. In order to reach the back one you will need a long universal spark plug socket. You can get the other three with a three inch extension. He found on mine that there is a cylinder head temperature sensor that is located between cylinders two and three, and there is a rubber seal that goes around the wiring harness that goes to the temp. sensor and my plug was not in place and it was letting water gather in the valley where the spark plugs are located. This water was allowed to sit there and rust the plugs to the cylinder head. He either replaced the rubber plug or just put the one that was there back in place and I should not have any water issues around the plugs from now on. The engine runs as smooth as silk after the plug replacement.
    thanks for the info
    80+ Posts Mgammon's Avatar
    May 2011
    New Bern, NC USA
    Thanks for the info Jerry .. Mucho appreciated ...
    G. Marshall Gammon (USN-Ret)
    New Bern, NC
    2015 Can Am Spider RT S
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Just a bit of information given to me a few years ago by a master mechanic (and friend) at a Lincoln dealership. The majority of issues with people who brought in the vehicle with the 2.3 motor as in the Stallion came from people using other than the recommended plug. For some reason, trying to use aftermarket plugs to possibly a different heat zone plays havoc on this motor. I have not changed my plugs yet (70k+) and it still is consistent with the gas mileage, starts and runs great. So when I ever change my plugs, it will be the same as what it came with. For what it's worth!
    Tomg
  1. Spark Plugs
    By lightnin in forum Harley Trike Conversions
    Last Post: 12-05-2016, 09:34 PM
  2. spark plugs
    By DJS in forum Honda Trikes
    Last Post: 06-03-2012, 04:26 PM
  3. spark plugs
    By geraldlanc in forum General Discussion
    Last Post: 03-24-2012, 09:03 AM
  4. Spark Plugs
    By drumdoctor in forum Home Built Trikes
    Last Post: 09-21-2011, 03:19 PM
  5. Spark plugs
    By John Luciano in forum General Discussion
    Last Post: 07-29-2010, 06:41 AM
