Likes Likes:  47
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: 1994 Genuine Lehman Trike Build
  1. #21
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    I believe the 1989 to 2001 FLH-FLT take the same Trike swingarm.
    As I stated above, the same pivot pin, trans/swingarm bushings and trans mount bushings. I know it will work back to 1989.
    It may even fit back to 1985 with slight modifications.
    Just curious, I had to beef up the top motor mounts on my 1989 Tour glide, Did you do the same or is it strong enough as the newer ones are?
  2. #22
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by pcombe View Post
    The frame is very similar to the 2007 and earlier FL and the swingarm attachment points are the same as well. I was concerned with the lightweight backbone of the FX and possibly braking the transmission tail housing, so I used solid pivot bushings and nylon fillers for the rear engine/transmission mount. The down side will be extra vibration, but the upside will be very limited lateral twisting of the engine/transmission assembly.
    That is my goal and no I didn't beef up the upper stabilizer bracket. I have the velvet links in the front and on top. I have an upper link reinforcement bracket if I need one later.
    Only put less than 10 miles on it basically to see if it had any rubbing or rattles. Still have the stock fork clamp but will see how it does.
    It feels like a big Sportster in handling. I had a Dyna trike that somehow felt bigger and heavier.
    Time will tell the 'rest' of the story !!!!
    Jim Murphy
    Iron Butt Rider 2001
  3. #23
    Apr 2010
    Shenandoah Valley of Virginia
    Wow, I just now tonight seen this thread. I guess I missed it during my own dark days, sorry to read you had some too, hope things are looking up.
    Trike looks great!
    Guess I need to read more rooms here, huh?
  4. #24
    80+ Posts tbird71's Avatar
    Feb 2018
    Lake Placid, FL (winter) Ramsey, IL (summer)
    Default Lee;
    Am about to buy a 1993 Aspencade with a Lehman trike kit
    I'm wondering whether you can identify it?
    Has the gold lehman logo on right has lehman factory wheels
    I can get pics if that'll help. It couldnt be same age as bike as 1994 was first yr production? Just want to know what I'm buying
    Ride Safe!
    Tom
    2019 Tri Glide (Black with pins)
    2015 FLHTP Electra Glide Police (Black w/o pins)
  5. #25
    Quote Originally Posted by tbird71 View Post
    Tom Jim has passed. If you post pictures MAYBE a member will be able to help.
  6. #26
    400+ Posts
    Feb 2020
    Washington Pa USA
    Looks good
  1. Lehman Trike Parts & Info Thread
    By Lee H. Mann in forum Lehman Trike
    Last Post: 08-28-2023, 10:51 PM
  2. 1994 Kawasaki vulcan 1500 brake light switches
    By jmk865 in forum Suzuki - Kawasaki Trikes
    Last Post: 04-17-2021, 02:44 AM
  3. 1994 GW trike
    By jackt in forum Honda Trikes
    Last Post: 02-14-2016, 10:43 AM
  4. 1994 Vulcan 1500 w/Tow-Pac.....oil leak
    Last Post: 04-16-2015, 04:23 PM
  5. 1994 Vulcan 1500 oil consumption???
    Last Post: 08-01-2014, 11:45 AM
