Results 1 to 8 of 8
Thread: Need Stallion Trike Frame Measurements
    Jul 2016
    madisonville, Texas
    Default Need Stallion Trike Frame Measurements
    I need to know the wheelbase measurement, the distance between the center of the front and rear wheels?
    Quote Originally Posted by a1stallion View Post
    Welcome..To Trike Talk..
    I don't have a Stallion so i can't help you on the measurements.. Im sure someone with a Stallion will chime in with the answer. But my old Brooklyn curiosity makes me ask why do you need them...
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    To answer your question, axle to axle is 90" When I was shopping for a hauling trailer for the Stallion I did a lot of measuring, so in case you ever need to know these here they are:
    114” (9’ 6”) - Front of front tire to rear of rear tires
    108” (9’) - Front of body to rear axle
    90” (7’6”) – Axle to Axle
    8” – Front tire width
    64” (5’ 4”) – Widest part of body
    124” (10’ 4”) – Total length of body
    62” (5’ 2”) – Outside of rear tire to outside of rear tire
    3.75” – Clearance from ground
    1736 lbs – Curb weight (1790 lbs when weighed with 1/3 tank fuel)
    Towing Capacity – 665 lbs
    Tires (BF Goodrich) pressure: 42 psi front - 24-25 psi rear
    Trailer bed needed: 6’ x 12’ (6’ x 11’ minimum clearance)
    72” (6’) x 132” (11’) - 204”
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Good answer Dean
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Dean H View Post
    Front tire should be between 36-38 psi. If you run the original 42 psi in the front tire, you will wind up with cupping and the center will wear quicker. I know as not only was I advised to lower the front tire pressures by someone at TMS (who is no longer there) but, when I changed my front tire at 30k the measurements of the tread depth said it all--too much air pressure from the factory. I also lowered my front shock setting from the top to one lower and the trike rides better than it ever did.
    Tomg
    Oct 2010
    Tampa, FL
Size:  185.3 KBName:  20160818_105444.jpg
    Quote Originally Posted by tomg View Post
    Tomg
    I have run 41-42 psi up front ever since I had my Stallion and no cupping on my tire. This tire has 25,100 miles on it and hardly showing wear.
    Dean - 480.734.7161
    Tampa, FL
    '09 Stallion #643
    Yep thats a nice looking tire.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Love the Trike Talk brain trust...
  1. Stallion frame broken...2010 model
    By ODDOMAN in forum Stallion Trikes
    Last Post: 02-06-2015, 01:17 PM
  2. vw trike frame
    By vwbuild in forum VW Powered Trikes
    Last Post: 01-03-2015, 05:28 PM
  3. where to buy vw trike frame?
    By carl1953 in forum VW Powered Trikes
    Last Post: 09-10-2014, 01:15 PM
  4. Trunk measurements
    By TomWoodgeard in forum Harley Trike Conversions
    Last Post: 09-21-2013, 07:43 PM
  5. New Trike, cracked frame
    By bikerlarry in forum Honda Trikes
    Last Post: 11-20-2011, 09:12 PM
