Results 1 to 12 of 12
Thread: Post your Tow-Pac Fender lights rear view and how you did it!
    200+ Posts HarleyBob's Avatar
    Oct 2017
    HOUMA, Louiaiana
    Default Post your Tow-Pac Fender lights rear view and how you did it!
    I'm waiting for my Tow-Pac InstaTrike W/ 15" wheels, Kit to come in, that will go on my Harley Ultra Classic, I hope next week.
    I'm wanting to install Running, Turn, and brake lights on the flat part on the fender where the reflectors go,
    before I send them out to be painted.
    I'm reading here in old post, that it's hard to find a good way to run the wires under the fiber glass finders,
    and Wire them to the bike!
    Has anyone come up with a good way to do this?
    Does anyone have pictures of the install?
    Where did you purchased the lights and other items used, and just how you did it.
    Any help and Pictures would be appreciated. Thanks!
    300+ Posts dadztoy's Avatar
    Dec 2011
    Georgetown, Tennessee, USA
    Quote Originally Posted by HarleyBob View Post
    I'm waiting for my Tow-Pac InstaTrike W/ 15" wheels, Kit to come in, that will go on my Harley Ultra Classic, I hope next week.I'm wanting to install Running, Turn, and brake lights on the flat part on the fender where the reflectors go,before I send them out to be painted.
    Look at this post -
    http://www.triketalk.com/forum/threa...ta-Trike/page2
    Post # 11 and post #16
    My LED lights came from etrailer and I used the additional chromed plastic frame as well...
    https://www.etrailer.com/Trailer-Lig...cs/AL82AB.html
    Les
    Oct 2017
    HOUMA, Louiaiana
    Quote Originally Posted by dadztoy View Post
    Look at this post -
    Les
    Thanks Les, $4.00 each, YEA! I'll look into it!
    Can you tell me the dimension of the flat part on the finder of the Tow-Pac?
    Dec 2011
    Bob,
    I'm out of town right now and won't be back for a few weeks, but I can measure it when I get back, or maybe someone else can chime in and give you the measurements...
    Oct 2017
    HOUMA, Louiaiana
    Thanks Les, I'm looking at these but not sure if they will fit.
    https://www.etrailer.com/Trailer-Lig...s/RVSTL10.html
    Oct 2017
    HOUMA, Louiaiana
    I just got off the phone with Tow-Pac
    My finders are different than your's, seems the 15" wheels have different fenders
    but have a flat part on them at the rear. Their concern was the weight of the lights.
    So I will see what the finders look like when they come in.
    I may fiberglass some brackets for the light wires and at the same time
    beef up the finders if I can, or I will have to drill holes in the finders for wire brackets.
    They are saying around 11-7-17 it should be at my door, a week from today!
    Dec 2011
    Bob,
    Didn't think of the different fender sizes for the 15" wheels but it makes sense... Those lights look pretty large but if the fenders for the 15" wheels are larger, they may fit...
    I chose the red and yellow LED's as I wanted to maintain yellow colored lights for the turn signals to match the Wing... The original lights I installed are still going strong after their installation in 2013 when I got my Tow Pac kit...
    I can give you a link for the stick on wire holders I use... They are by Panduit and are available from Mouser Electronics and they stick quite aggressively... Again, I still am using those I installed 4+ years ago when I installed the lights...
    https://www.mouser.com/ProductDetail...Ml53af7oq5j7F8
    Looking forward to seeing your finished kit when installed...
    Les
    If I was putting lights on an ultra, I think I'd go with stock ultra tail lights and wire them to act as tail/brake and signal ... Just a thought. I may even have a couple you can have, you pay the shipping if I can find them.
    Oct 2017
    HOUMA, Louiaiana
    Bob,
    Les
    Les
    Thanks a lot. I ordered 20 of them last night. If I don't use all of them on the bike I will use them around my shop, or music studio!
    Oct 2017
    HOUMA, Louiaiana
    Sounds like a plan! If you find them could you send me a picture. Thanks
    Oct 2017
    HOUMA, Louiaiana
    I'm looking at these also. 6" long so they may not fit.
    I changed all my amber blinker lights to red some times back, so I will go with red!
    https://www.ebay.com/itm/1-Red-6-10-...19.m1438.l2649
    As soon as the kit comes in I will know!
    I'm biting at the bit! LOL!
    Dec 2011
    Les
    When you use them, as with all sticky tape products, clean the surface with alcohol thoroughly and let dry... After application, let them sit for 24 hours for the adhesive to cure... The Panduit cable tires are quite good and you shouldn't have a problem with them coming off if you apply them correctly...
    Les
  1. rear view mirror
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 11-28-2014, 04:48 PM
  2. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
  3. rear view mirror
    By Ed Hobgood in forum Stallion Trikes
    Last Post: 06-22-2012, 08:16 AM
  4. Additional rear view mirrors
    By Lexi in forum Stallion Trikes
    Last Post: 10-15-2010, 11:15 AM
