Likes Likes:  1
Results 1 to 5 of 5
Thread: Lehman Monarch II help
    80+ Posts
    Sep 2014
    SE New England
    Default Lehman Monarch II help
    I have a 2012 GL 1800 with a Lehman Monarch II Kit.
    Would like to know at what point on the Kit or Bikes frame would be the best place to jack the rig up so that the solid axle rear end would hang down to the lowest point.
    Also, what to do with the Kits Aux. Shock as well as the GL's shock
    It looks like placing a jack on the Kits frame up under as close to the center of the Trike would be the best place. However, I'm not sure where. I've read that some use the trailer hitch bar but I have concerns as it looks like it would create a long moment arm resulting in significant stress on the welds.
    What I have to work with are (2) 8" high ramps, (2) table platform jacks, 2 jack stands, and a Pit Bull motorcycle lift
    Any help would be greatly appreciated.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by durango9 View Post
    What is it exactly that you are trying to do ??? Then I may be able to help.
    Jim Murphy
    Iron Butt Rider 2001
    80+ Posts
    Sep 2014
    SE New England
    For one thing, I want to replace the Standard weight Aux. Shock with a heavy duty. I have a complete heavy duty assembly.
    Martinsburg, WV
    Place a jack beneath the rear axle housing differential.
    Raise the rear axle enough to put jack stands on either side.
    I usually remove the wheels and place the stands under the brake rotor. Not on the edge of the rotor but on the flat of the rotor.
    Lower the jack until the rotors are just resting on the stands. If your trike has efx boards and they were installed with an additional support bracket, you can place the flat jack beneath that support bracket and raise the motorcycle. If there is no support bracket where the center stand was mounted, you can take a small 2x4 and place it beneath where the old center stand was and raise the motorcycle from that point.
    It will be necessary to disconnect dog-bone-link, or as honda refers to it “rod-sub-assembly” at the arm-sub-assembly.
    Break loose the bolt and nut and remove the nut.
    Using your paddle jack you can now raise the motorcycle slowly until you can rotate the bolt and remove it.
    Now you can raise the motorcycle enough to easily remove the aux shock.
    If you need more lift, you can adjust it with the paddle jack.
    I suggest installing the shock on the lowest preload and adjusting the preload after the shock is installed.
    Jim Murphy
    80+ Posts
    Sep 2014
    SE New England
    Thanks very much Jim.
    This is the exactly the instruction details that I need to do the job. You help as always is very much appreciated.
  1. 2003 Lehman Monarch II
    By CyberVet65 in forum Lehman Trike
    Last Post: 12-05-2015, 06:20 PM
  2. 2003 Lehman Monarch II
    Last Post: 10-15-2015, 08:54 AM
  3. Lehman Monarch 1 hitch
    By slywing in forum Honda Trikes
    Last Post: 10-02-2015, 03:31 PM
  4. Lehman Monarch II question
    By Scarecrow in forum Lehman Trike
    Last Post: 03-29-2015, 03:20 PM
  5. Germany need your help, Lehman Monarch
    By ramon in forum Lehman Trike
    Last Post: 11-24-2012, 07:47 PM
