Looking to change oil coolers Harley cooler needs help. Are there any members using the Ultra Cool oil coolers they seem to move more air than the Jagg oil coolers do but are they as good Jagg? all comments certainly welcome. Ride safe Fred
Dunno about looks...that is subjective. But we tested the Ultra-Cool & the Jagg several years ago, and the Jagg cooled better, by over 15 degrees in stop & go, and 10 degrees at highway speed. Both were better than the factory oil cooler.
This is the Jagg we tested-
You can see more photos and details on it HERE.
The Ultra-Cool we tested is NOT the one they are making now. The one now looks more like a radiator. Would be interesting to know what they say about how much better it works than their previous model.
Might be time for us to do some more testing.
www.DKCustom.com
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
The fan assisted oil cooler on the '17-'18 Freewheeler is larger and more effective than the OEM oil coolers on previous year Twin Cams.
Harley use to use the Jagg oil coolers as their factory OEM oil coolers, but then they went to a less expensive cooler that is not as effective as the Jagg. The internal design of an oil cooler has a major effect on how the oil flows and dissipates heat. The less expensive OEM coolers are not as good as the Jagg, inch for inch.
BUT, the oil coolers on the 17+ Freewheelers are larger, and that makes up for a lot.
On the 2018 M8 Softails, the oil cooler is even larger than the larger one on the Freewheelers.
www.DKCustom.com
A little bit off subject, but what a horrible place to locate that oil cooler.
I agree, much of the wind is blocked by the front tire, plus it is vulnerable to rock dings and getting plugged up. Surprisingly there are not too many failures.
BUT, that is where HD puts the OEM cooler, so lots of folks like to do it.
I prefer of the downtube, where there is much more wind, and less likelihood of dings and getting dirty/plugged up. They work much better there. But with lower fairings, the largest you can go is the 6 Row. Without lowers, you can go with a 10 row (with or without a fan assist).
I have a 6 row on my Tri-Glide...
...and a 10 row on my Softail...
Both of them much more in the wind than the low-mount HD style.
btw, Fred, on my 2011 Tri-Glide, I ran two oil coolers...one in the factory location, and a second one off the downtube. Something to consider...instead of spending $ and still only having one oil cooler...spend a little less $ and have two.
Oil Cooler LINK for secondary cooler for bikes/trikes with lowers.
www.DKCustom.com
If you have Wet Heads don't order. Their web site will state they have a Ultra-Cool to fit the Tri Glide. But at this time they do not. Reason I know, I ordered one for my 2016 Tri Glide, while trying install the bracket, it would not fit. Called the company and they confirm that it would not fit. They offer a refund and once I shipped it, back I received the refund within 24 hrs.
Supposedly they are making a bracket that will fit, but it is several months away.
Nuc
www.DKCustom.com
The only oil cooler that works with the Twin Cooled is the one at this LINK.
We designed it, and patented it a year or so ago.
I talked to Ultracool back in 2015 and they said they had one coming out soon...they still don't have it.
We spent a lot of time on this...because the Twin Cool motors (both the Twin Cam and the M8) have a real challenge with oil temps. They actually run HOTTER than the non- Twin Cooled.
The only other place we found to put an oil cooler on the Twin Cooled Trikes was under the body. And there is enough room there to put a 10 row, even a fan assisted 10 row. But the 6 row, right behind the lower fairing does such a good job that we never bothered to put it into production.
www.DKCustom.com
www.DKCustom.com
I have the Ultra-Cool, no complaints, seems like the oil temp gauge will stay lower for a longer time than with OEM cooler. I bought it used and the thermostat for the fans doesn't want to turn them on. I simply installed a manual switch. The little LED indicator light comes on when I turn on the fans. I haven't played with a thermometer, but I'm sure the oil is cooler with the UC than without. If I get in heavy traffic, the rumpety-rump idle kicks in just like before. The oil might be cooler, but the heads still get hot when no air is moving. DK's remote oil filter mount helps too. Considering the Mighty Mites, but I just can't seem to get past the way they look.
