Results 1 to 9 of 9
Thread: Triumph rocket trke
    Aug 2014
    Anchorage, Alaska
    Default Triumph rocket trke
    Hi can't find a trike kit to fit a 2005 rocket 3 so I'm building one using a corvette rear end can any one tell me which way the drive line turns clock wise or counter please no gussing I can do that thanks
    Aug 2014
    Anchorage, Alaska
    Default Re: Triumph rocket trke
    Motor trike makes kits for 2008 and later and will not sell one with out installation my rocket is 2005 thanks
    30+ Posts
    Jan 2013
    Slidell, LA
    Quote Originally Posted by Big Dan View Post
    How about an educated guess? The ring and pinion / drive assembly is on the left side of the motorcycle, correct? Viewed from the left, the rear wheel turns counterclockwise as the motorcycle moves forward. For that to happen, the pinion must turn clockwise viewed from the rear. Follow me? This would be the opposite of most automotive applications, so using a Corvette differential without modifications will give you 5 reverse gears. How will you deal with that?
    Bob
    Aug 2014
    Anchorage, Alaska
    Default Re: Triumph rocket trike
    Quote Originally Posted by bobscogin View Post
    Bob
    Bob after more research I found a jaguar rear end spins the right way and a top fuel car builder and racer is going to help me with it thanks
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Curious to see how this build goes ,,,keep us informed and pics would be nice .Good luck with it .
    we all have our faults .....others point them out to us......guess we know what theirs are
    30+ Posts
    Jan 2013
    Slidell, LA
    Curious as to which model that would be? I'm not aware of any automotive applications where the output turns clockwise viewed from the rear looking forward as the Rocket III does. Essentially, if the pinion is on the driver's (left) side of the ring gear, it will work. If on the passenger (right) side, it's backwards. The exception could be reverse cut ring/pinion sets for front axle applications in a 4X4.
    Bob
    10+ Posts Volunteer FireFighter 420's Avatar
    Feb 2014
    Paris, TN, USA
    I know I am a little late to the Thread but...
    http://www.hannigantrikes.com/produc...ke-conversion/
    This is actually in the Hannigan Showroom
    Either way, I personally, like the Triumph trikes (easier to hold up )
    FireFighter 420:pepper:
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    PROJECT PICS PLEASE...
  1. Trike kit for Triumph motorcycle
    By Scorpio49 in forum General Discussion
    Last Post: 03-02-2014, 03:13 PM
  2. triumph trikr
    By whitefatboy in forum Home Built Trikes
    Last Post: 02-07-2013, 02:55 PM
  3. Triumph Rocket
    By Nana in forum General Discussion
    Last Post: 07-21-2012, 07:19 AM
  4. New Triumph !
    By BlueTrinity in forum General Discussion
    Last Post: 11-20-2009, 01:38 PM
