Likes Likes:  16
Thanks Thanks:  4
Results 1 to 20 of 31
Thread: Conversion from Drum to Disc Brakes possible?
    5+ Posts bosslady's Avatar
    Feb 2019
    Salem, SC, USA
    Cool Conversion from Drum to Disc Brakes possible?
    My husband and I just purchased a 1999 HD FLHRCI (Road King Classic) with a Motortrike conversion kit. I think it's a Trog kit (unsure) but it has air ride suspension and
    drum brakes. Does anyone know if this can be converted to Disc brakes and what the cost would be? Thanks in advance!
    Patti.........Welcome to Trike -Talk............
    Feb 2019
    Salem, SC, USA
    Cool
    Thank you!
    Patti welcome aboard
    I don't know about cost but maybe Richard will step in to give you guidance.
    Jun 2010
    Indianapolis, In.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Been one of those crazy days today.. The official MT reply would be, our solid axle HD conversions are only available with drum brakes & we do not have a disc brake system that will work with our solid axle kits (liability & all that jazz).
    With that being said much like the write up that was linked above it is possible & has been done more than once with aftermarket parts & components. The thing you do want to stay aware of & keep in the front of your mind when shopping - you have a limited master cylinder size & limited pedal travel and no power brakes (like most cars that calipers are "borrowed" from.
    thank you for responding richard
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Thumbs up
    Quote Originally Posted by trike tech View Post
    Richard, the kit referred to is the one Lehman used on the rear axles before 2010. The motorcycle m/c was used with a residual check valve at the tee. I have converted the shaft drive MT straight axle from drum to disc, but never done the belt drive model. Probably because they are 5 lug axles. What axle bearings are used in the MT (RW207CCRA is used in all Lehman 2012 and earlier) ?
    Patti, welcome to Trike Talk from West Virginia.
    Jim Murphy
    Iron Butt Rider 2001
    200+ Posts
    Feb 2017
    Arp, TX - USA
    I've got a "cheat sheet" for the common parts store parts for the 7.5 diff (shaft drive bikes like the Valkyrie); the axle bearings are p/n R1563 (ironically enough, it's also the same bearings my Jeep uses ) On our HD conversions we do use the same 207 bearing that they used, yes.
  11. #10
    Feb 2019
    Salem, SC, USA
    I guess I'm wondering.....is there a reason why the Trog kit doesn't have the disk brake option? I guess I just assumed a company like MT would offer that, or at the very least, begin looking into it. The only other option would be to see about switching completely over to the Gladiator kit.
    Well, guess it isn't a big deal. Heck, I'm just happy to have the trike....always wanted one. Beggars can't be choosers!
  12. #11
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to TT to both you and your hubby, Bosslady/Patti.
    Anything can be done with the right mechanic/fabricator. Unfortunately, the cost to do the conversion may outweigh the added braking performance you get from such a project. Especially if you have to pay someone to research, engineer, secure parts, and actually go hands on to modify your trike. Not trying to discourage you however if that's what you really want.
    Are the brakes not working? (Just wondering why you feel the need to "upgrade")
  13. #12
    Feb 2019
    Salem, SC, USA
    They are working fine as far as I know. The hubby says the trike pulls to the right a bit when the rear brakes are used.
  14. #13
    Dec 2012
    Santee
    need to adjust the left brake, if it pulls to the right.
    Ray
    2017 Harley Triglide
    Tijuana Border
  15. #14
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  16. #15
    Quote Originally Posted by Rmitchell55 View Post
    It would not hurt to pull the wheels and drums and have a look @ the shoes, wheel cylinders and hardware
    Bleeding the brakes will be a plus to get old moisture bearing fluid out of the system
  17. DKCustoms postbit
  18. #16
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Smile Hello!
    Patti, Welcome from SW Arkansas.
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  19. #17
    Feb 2019
    Salem, SC, USA
    Quote Originally Posted by ShapeShifter View Post
    Thanks! :-D
  20. #18
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Quote Originally Posted by bosslady View Post
    The short answer - the calipers for the s/a kits were designed around the linked braking system of the GL1800. It was looked into briefly as a conversion for other s/a bikes but they did not work well at all because of the difference in master cylinder bore & stroke (along with the other bikes only feeding a single line to the rear). With either port being used it was either HORRIBLE braking or the pedal was so hard you had to stand up on the pedal to apply enough pressure to do anything.
    The other side of that coin - The drum brakes are basic automotive parts readily available at any parts store. The calipers are custom manufactured & only available through Motor Trike dealers & are pricey as a result.
  21. #19
    20+ Posts Pappy49's Avatar
    Apr 2018
    San Marcos, Texas, USA
    Richard, is there any kind of a 'cheat sheet' or parts list for the Trog axles. I need to break mine on my '02 Glide down and replace the bearings. I would think you would have an illustrated parts diagram available.
  22. #20
    Sep 2018
    OFallon, Missouri U.S.A.
    Hi, for your info, I ride a GoldWing Trike with Lehman conversion with drum brakes. I ask our GoldWing dealer the same question about changing to disc brakes on my trike. He ask me why? He said most people preferred the stopping power of drum brakes because they thought they stopped better than disc brakes. Much more shoe surface against the drum. That`s what I was told. I rode a Trike at the dealer with disc brakes and I really could not tell much difference.
  1. Lehman Monarc II 2004 drum to disc conversion
    By Randy Cheesman in forum Honda Trikes
    Last Post: 02-09-2024, 03:17 PM
  2. Drum to Disc Brake Conversion
    By stanley175 in forum Lehman Trike
    Last Post: 12-05-2023, 08:25 AM
  3. Drum to Disc Conversion for Motortrike 9" drum brake system
    By Lee H. Mann in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-08-2018, 03:41 PM
  4. Drum Brakes to Disc????
    By grumpy in forum Honda Trikes
    Last Post: 05-29-2016, 09:21 PM
  5. Drum to Disc Brake
    By Lee H. Mann in forum Lehman Trike
    Last Post: 05-01-2016, 11:03 PM
