Likes Likes:  6
Thanks Thanks:  3
Results 1 to 12 of 12
Thread: Gawd I hate handlebar electrics
    300+ Posts RedOregon's Avatar
    Aug 2015
    south of San Antonio
    Default Gawd I hate handlebar electrics
    Okay, new handlebars, to run the wires internal, had to pop the connectors and reconnect. Yesterday in the Hill Country, got a check engine light, thank gawd I have an FP3. Error codes (didn't screen cap them dammit) were something about switches not talking right, two inputs didn't match, and a warning that I might go to limp mode. Luckily I didn't.
    Other symptom was the cruise control would *not* kick off by grabbing the front brake. Scary but the back brake still cancelled it, as did the cruise control button.
    Anyone else gone through this? I'd prefer to tear down as little as possible, of course.
    2024 Tri Glide! Only modifications so far - transferred Rider backrest from old 2015 Freewheeler, just added highway pegs!
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    Default Wiring
    Depending whether or not you pulled wire pins from connectors and got them back in wrong spot or you have a wire grounding from a pinch or insulation scraped off. If you pulled pins,you are going to need a wiring schematic. If not,I suggest redoing job again,looking for any problems with wiring. Wiring handle bars internally always has it share of problems.
    Aug 2015
    Quote Originally Posted by GTK View Post
    Yeah, pulled pins, but drew up a detailed diagram of each connector and I'm pretty sure I got them back together right, since I got no errors on the first two or three rides.
    Guessing some insulation got nicked and now a short. Good Luck.
    + 1 to fuzzy or pinched wire
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default Those dang wires!
    Quote Originally Posted by RedOregon View Post
    Hey Red
    What was the final outcome on your check engine light handlebar change? I finished my change yesterday. Switch on in garage, all lights, horn and cruise comes on. Went for ride around neighborhood to see how I liked the new bars. About four blocks and check engine light comes on. Have not checked codes yet but will do that today. Help!
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Years ago I did a friends handlebars. Was sure I got all wires back in right hole. WRONG. One wire (well actually 2) was misplaced. Luckily I checked all before it was all buttoned up..switched them & all was OK. Hope ya get it fixed Red.
    Aug 2015
    Sorry I've been away for quite a while, changes here and there got in the way. Closer on this one: had a bad rear brake light sensor that seemed to have caused all the issues. And I have a strong feeling that it took a few rides for the brain box to adapt to the wiring length changes in the bars - no proof of this one, but anecdotal mentions of resistance changes that the CANBUS takes a while to adapt to kinda points me that way.
    Bottom line: replaced the rear brake light sensor, and a couple rides later, all was well.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Good to read it all is working now.
    I also have a strong aversion to handlebar electrics.
    www.DKCustom.com
    I do not like any tricity
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yeah, I well remember some of your stories bout it.
    I do not mind electricity at all. In fact, I find wiring up shops, house, etc. to be oddly satisfying. What I do NOT like is the finicky reliability (or lack thereof) of HD handlebar switches.
    www.DKCustom.com
  1. I hate self-canceling Turn Signals...Grrrrr
    By skuuter in forum Honda Trikes
    Last Post: 10-16-2023, 07:26 PM
  2. Fog light install - Thank gawd for YouTube!
    By Dockem in forum Honda Trikes
    Last Post: 07-04-2016, 08:17 AM
  3. I hate snow
    By americanbadass in forum General Discussion
    Last Post: 01-14-2013, 05:46 PM
  4. Hate to do it,,,....
    By rmrc51 in forum General Discussion
    Last Post: 04-22-2012, 09:21 AM
