Likes Likes:  9
Thanks Thanks:  1
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 46 of 46
Thread: front coil overs for a 700 lb front end with leading link. help question
  1. #41
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    well I'm sure I will have to remove calipers to remove wheel also,,,
    don't plan on removing it to often once done as i'm plenty tired of repainting stuff that I scratch now!!
    mike aka magoo
    hd sidecar rig/building v6 supercharged trike
    "even a blind squirrel finds a nut once in awhile"
  2. #42
    90+ Posts
    Edwardsville, IL USA
    Awesome read! I'm just starting to plan a V8 build and was wondering what the measurements of your front fork tubing is?
    Thanks.
  3. #43
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default allmost there... and looking good!
    butchvoss.....looks good and looks strong.. your almost there! I put my front end the the scale today..340#, no rider. 370 with me in the seat. but I sit toward the rear. see last winter trike.. my question is, will your front wheel load be 700# with 2 up or what ? havn't seen the rest of your trike, maybe earlier posts?? larry
  4. #44
    50+ Posts
    May 2014
    NH
    Quote Originally Posted by LarryA View Post
    My front end is 640 with the wife and i... Just weighed it before i put it up in garage for winter mods a couple of weeks ago
    Quote Originally Posted by Eggman View Post
    Awesome read!
    Thanks.
    Thanks.[/QUOTE]
    I ordered Two of 4 ft of 2 inch .250 dom tubing and had the trees custom made . I think with out going to garage they measure at 40 inchs. I started long and reduced as i was adjusting rake and trail Going to make a couple of mods to give more action to front for these pothole roads of NH this winter hopefully
    thanks
  5. #45
    90+ Posts
    Thanks. I was kinda thinking that they were 2", didn't know about the wall thickness.
    Now I'm just trying to figure out what the optimum trail is for the leading link style forks. The sweet spot, if you will.
  6. #46
    750+ Posts
    Jan 2010
    east windsor ct
    personally i like about 1-1/2 to 2-1/2 inches
    but what is nice about a LL you can have it adjustable i figure for that range when i lay it out go with the middle hole dont think ive ever moved one
  1. Needing a leading link front end for my vw
    By carlpaulman in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-04-2015, 08:52 AM
  2. leading link front end
    By stevie in forum Home Built Trikes
    Last Post: 09-30-2014, 01:42 PM
  3. My New Leading Link Front End
    By Shadowlord in forum VW Powered Trikes
    Last Post: 05-20-2013, 08:52 AM
  4. LL front end build (leading link)
    By redneckray in forum VW Powered Trikes
    Last Post: 04-28-2013, 08:07 AM
  5. leading link front forks
    By stevie in forum General Discussion
    Last Post: 01-29-2013, 09:34 PM
