Has anyone replaced the oem tail light bulb on a Tri Glide with a #1157 led bulb ?
How did it work out ?
Hi Gary, Welcome to Trike Talk and your first post
Not a Triglide, but I use them on my FLRT Freewheeler
You will probably have to sync it to your BCM by turning the ignition on and running the 4 ways for a minute or 2
These are available every where
The new tri Glide uses a bayonet lug filament bulb and the 1157 bulb is supposed to be a plug and play for it. I want to add a flasher for my brake lights but you need to have LED bulbs. To change both tail light assemblies would cost about 1K. So I thought if I could change only the bulbs then maybe the flashing module would work with them.
Gary.....What Trike do you own......Your profile says you are looking for a trike..???
I own a 2022 Tri Glide Ultra
Get a set of these, they have flasher built in, flash 3 times then steady. Note, some of the LED bulbs are directional (diode) so if they do not light, try reversing the bulb in the socket.
I have these on my 2019 Trike and they work just fine.
https://www.amazon.com/gp/product/B07F9JXWT2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I went to Amazon to order these and their website says it does not fit my 2021 Tri Glide. If the 3157 is a replacement for the stock then I would think these would work. May just get the ones at AutoZone but would really like the ALLA. Can someone please verify that the ALLA really do fit the 2021 Tri Glide.
Received these in the mail this morn. I put them in and yes indeed, they do fit perfectly. I love the way they flash when hitting the brakes, kinda have a strange flash for turn signals though. THEN, I turned up the volume on my radio. So much static it made the music hard to understand. Yea, serious static, and got much worse with turn signals applied, or brakes. They would work great for anyone not desiring to use the radio, for me, they came out and stock bulbs went back in. Don't know what I'm going to do with the ALLA bulbs but I can say they will not be going back on my '21 trike.
