Likes Likes:  11
Thanks Thanks:  1
Results 1 to 20 of 21
Thread: Upgraded handlebars
    Jan 2019
    Scottsdale
    Default Upgraded handlebars
    ​I noticed when I took the 2019 TriGlide out for a test ride, I started to get a knot between my shoulder blades. I was having to lean too far forward. I am 5'7" with a 30" inseam. The seat was fine but hoping to find some bars that will come back to me a bit more for an upright riding position. Any suggestions would be appreciated.
    depends on how much money you want to spend. I have helibars on my tri glide 13. expensive but they are fully adjustable I have bad wrists and I ride with no pain
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    I have a 15 Tri and I went with the HD 2" pullbacks, I'm 5' 8 with a 30" inseam. I really like them and didn't need any extenders for clutch, brake, or throttle.
    Dec 2013
    Clarion PA USA
    I'm 5'8" 30" inseam I have 2+2 wide sweepers Khrome werks bars check my photos in my profile albums good luck with the search Fred Name:  DSC01001.JPG
Size:  161.7 KBName:  DSC01011.JPG
Size:  161.6 KBName:  DSC01013.JPG
Size:  162.7 KBName:  DSC01022.JPG
Size:  160.3 KBName:  DSC01024.JPG
    PS I got to the computer
    70+ Posts TWISTED1's Avatar
    Apr 2017
    Mehama, Oregon
    I am 5'10" with 28" inseam. Short legs I guess. I went with a tall boy seat (from HD) to sit lower and further back. Then after I got the seat that fit me best I went the Carlini 16" gangster apes. I prefer the pull back and angle of the Carlini bars. The bars are now at shoulder level and no leaning over. It does put your hands over the faring and any protection from the air but then again i have never had a faring before so it is not that big of a deal. IMHO I would make sure the seat you have is the most comfortable seat for you then look at bars. I still cant figure out how to post a picture to show you where they end up but if you look at DK Products home page that is my trike in the slide show at the top of the page.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by HDDaddy7838 View Post
    Did you attempt to adjust them?
    Dec 2013
    Clarion PA USA
    I want to add the wider bars make it so much easier to steer and the added height of 2" and added length of 2" of grips. However check out Khrome Werks website they have a full line on bars at a workingman's budget. I would have sold the trike if I had not found out about these bars have ended my back and shoulder issues on long rides for that matter any rides. Good luck in your search Travel safe Fred
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    That shoulder blade stabbing is definitely a bar issue. Choosing the right one can also be a real confusing issue.
    Sit normaly , eyes closed , simulating ware your hands are to be with your elbows bent , not straight, and have some one measure your hand distance from what you have. As Fred stated, Krome Works has a good selection as how to determine what you need. I’m 6’ and the 2x2 worked for me. You might need more. Measure up to find out. Do it once. Your welcome.
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    That should be a given,but handlebar adjustment on a Tri Glide isn't a piece of cake like it is on a Freewheeler.
  11. #10
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by GTK View Post
    I think you are correct. My brother in law had a Tri and wanted to set the bars back. Cost him $900.00. Later when he sold his Tri and bought a Wing he did the same thing. Moved them back 2 or 3 inches for less than $100.00
  12. #11
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    You can’t get any more reach with stock bars. A TG replacement is a all day ,+ a 6 pack job. Labor intensive. Average dealer cost $900 - $1000 . But worth it if your not a DIYS guy/gal.
  13. #12
    Dec 2013
    Clarion PA USA
    Depending on the year 13 and back have cable clutch later hydraulic. I did our 09' for less than three hundred. Newer you have Less expense
  14. #13
    450+ Posts arnie's Avatar
    Dec 2011
    camp grove,il.usa
    Around here we can drink a six pack in 2 - 3 hrs. & the handle bars will be finished before the six pack!
  15. #14
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I've read good reports about the Khrome Werks 2+2 sweepers but I've never seen them on a bike or tried them myself. Personally I'm a big fan of the Wild One Chubby bars - I've had them one three bikes and now my TG. The Chubby Bagger Low WO579 are what I have. Don't be misled by the 'low' description as they are taller and wider than the stock bars by about 2" as I recall. I guess the 'low' designation is to differentiate them from apes.
  16. #15
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    Hill Country Custom Cycle could be another choice. They have from bare bars to the complete plug & play assembly.
  17. DKCustoms postbit
  18. #16
    750+ Posts
    May 2011
    peru,in,usa
    Default handlebars
    youtube changing handlebar on harley. look for the paul yafee. i rally like my 12 " pullbacks
  19. #17
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by eagle1 View Post
    Eagle 1, this is Eagle leader, the original poster flew the coup.
  20. #18
    100+ Posts Tadgh45's Avatar
    Jan 2015
    South Plainfield,NJ,USA
    Default KST Kustom Bars
    I recently put 10" KST Kustom Mayhem Bagger Bars on my '15 TriGlide and couldn't be happier.
    Tadgh45
    2015 Harley Tri-Glide, Mysterious Red Sunglo
    V&H Duals, 4" Rineharts, SE ventilation, DK Custom lift kit & lots more.
    Amateur extra / VE. Call- AB2ZK
    OEM/CERT/RACES/ARES/AUXCOMM & Skywarn
    NRA Benefactor member
    V.P. Firefighters Brotherhood MC
  21. #19
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    Just talked to my buddy down in Alabama. We will be in his area in November and we will do some rides together. He had a shop install 12" apes on his 2017 TG for just over $700 out-the-door. He said they were polished stainless bars and they did an excellent job for him.
    Not sure I would go with 12" but I'm going to try his out when I get there. He said they had 10" available for sure. He had an estimate from a couple Harley dealers and they were both in the $1,200 to $1,300 range.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
  22. #20
    100+ Posts
    Mar 2019
    Wilmot, SD, US
    I'm 5' 7" with 29" inseam, 190 lbs...picture short and round!
    I had the local Indy (A&A Cycle in Watertown, SD) install the Khromewerks 2+2 bars in the middle of July. Just returned from Sturgis Rally, and with about 1800 miles on them, they are great!
    By the way, bars were approx $121, set of Kury Iso grips $80, and install around $265....out the door for $472.70!! Not bad,... not bad at all. Very happy, and highly recommend A&A Cycle if in NE S Dakota.
    Bill
  1. Upgraded to a New 2017
    By CJAC in forum Harley Tri Glide
    Last Post: 08-04-2017, 09:48 AM
  2. Upgraded to 2014...What will I notice better?
    By hapbob in forum Harley Tri Glide
    Last Post: 01-31-2014, 11:46 PM
  3. Upgraded My Cell/GPS Interface
    By Gold Rush in forum Honda Trikes
    Last Post: 05-26-2012, 05:55 AM
  4. Upgraded rear speakers. Damaged them. Repaired them.
    By wonderment in forum Harley Trike Conversions
    Last Post: 08-29-2011, 01:17 PM
