Likes Likes:  3
Results 1 to 20 of 20
Thread: No Cat Exhaust
    20+ Posts Ron1z's Avatar
    Dec 2019
    Ocala, Florida
    Default No Cat Exhaust
    Thinking of buying and installing wild pig header pipe on my 2015, do I need to do a remap afterwards?
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Like asking whats the best oil you will get many answers,if you dont change the air filter you will be fine.This has been my experience and i have done several of my bikes.
    Ron, Twin Cam engines run too lean from the factory
    It would be a big plus to add some fuel
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Quote Originally Posted by Ron1z View Post
    Bought their stock decatted pipes for my 2016 Tri, but never installed. Just using a PV Tuner with DK's HiFlow 606 AC, Premium EBS and Cobra 909 Twin Slip ons.
    Decided not to mount the decatted pipes because I really liked the level of sound, especially at interstate speeds, after installing the new tune and didn't want want the trike any louder. You're an hour and a half from Wild Pig Pipes in Holly Hill, FL, so not a bad ride if you're not under any travel restrictions and they're still open for business. Wish ya the best!
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
    Old adage, if you modify before the engine or in the engine ... retune.
    Modify after the engine, slip ons ... tuning not needed.
    If you are riding a Twin Cam it is already to lean from the factory
    400+ Posts
    Feb 2008
    RADCLIFF, KY
    Quote Originally Posted by ShapeShifter View Post
    is the decatted pipe for sale?
    2017 Tri Glide, Bonnieville Blue / Fathom Blue
    2005 Bushtec Roadstar Trailer
    BLUE KNIGHTS, KY II
    AMA, HOG, Iron Butt Member
    Aug 2018
    SW, Arkansas, USA
    Quote Originally Posted by Casper View Post
    Frank, Presently I'm holding on to it hoping that I get to hear another owners Tri Glide with similar a/c, mufflers and a decatted head pipe. If I like how theirs sound, then will install the Wild Pig Head Pipe. If plans change, I'll list it in the Forms Classified Section. Thanks for asking....Wes
    90+ Posts
    May 2018
    princeton wv usa
    Default no cat
    removed cat from trike sounds like wolf now
  11. #10
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Did you buy a new head pipe without a cat or did you gut the stock head pipe? I'm leaning toward just gutting my stock head pipe.
  12. #11
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Quote Originally Posted by molokaimike View Post
    If you have the equipment and time to do your own head pipe, fine, from what I have heard it is cheaper to buy a head pipe off of ebay that has been done or from several other companies and that way you keep your head pipe in stock form, just a thought.
    All for now Trampas
  13. #12
    90+ Posts
    May 2018
    princeton wv usa
    Default no cat
    bought mine off ebay.like the sound. didt notice any differance in power
  14. #13
    If you gut your stock, just cut a rectangle out of the back, remove the platinum and weld the removed piece back in place.
    Unless you have a jig, cutting the pipe in two will lead to fitment issues when you install it. Welding causes warping, cutting causes loss of length, all reasons you need a jig.
    I got a wild pig off eBay and the fit was perfect. No issues with O2 sensors or anything else.
  15. #14
    Dec 2012
    Santee
    I bought a take-off from the dealer and took it home, strapped it down to my workbench and used a hammer and a piece of 2 inch flat bar and gutted it from the outlet side. Took a couple of hours beating on it and completely gutted it. Removd the bungs for the O2 sensor and welded in some 18 mm bungs for the wide range sensors and when I installed the Target Tune and the wide range O2 sensors I had to change the angle on the rear sensor and move the front one. Just plugged the front one and drilled another hole.
    Ray
    2017 Harley Triglide
    Tijuana Border
  16. #15
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Found one on Ebay from Wild Pig for $100, broke my wrist getting my wallet out.
  17. DKCustoms postbit
  18. #16
    150+ Posts lah2420's Avatar
    Oct 2013
    Texarkana, AR
    Quote Originally Posted by Trampas View Post
    All for now Trampas
    That's what I did. Bought one off of ebay already done for $125 and still have the original in case of need.
    2015 Tri Glide Vivid Black. Customization work in progress to make it mine-when not riding it.
  19. #17
    60+ Posts
    Mar 2010
    Western NY
    Found a stock header on Ebay for $89.00 (free shipping) Cut out three sides and folded out a flap to get cat. out.
    took about 30 minutes. Folded back and had a muffler shop weld the gaps for $15.00. Still have stock unit if I sell or trade.
    Sprayed that section of the pipe with high temp paint but it did not hold up well. Should have left it raw.
    '15 TG Red Sunglo/Cayenne, Chrome Forks & Wheels, LED's, TGlide Stuff Lift.
    Patriot Guard
    Previous HD's: '13 TriGlide, '13 Fat Bob, '05 Super Glide, '00 Heritage, '96 Heritage, '94 FLHTC, '77 FXR
  20. #18
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Got the pipe that I ordered from Wild Pig. They cut out the section that contained the cat and welded a new piece of pipe in it's place. The only issue I have is what might happen if I have to take the trike in for warranty work and they see that the head pipe does not have the Harley engraving on it. I've still got the original pipe so I guess I can always change it back before taking it in but that sounds like a PITA.
  21. #19
    Especially if you brake down 8 hundred miles from home and need warranty work from a strange dealer......But then what are the chances...?
  22. #20
    80+ Posts
    Cochise, AZ USA
    Default Go for it!
    Go for it!
    Bought a gutted head pipe off Ebay and gutted the stock mufflers! Had a loud cracking sound to it but felt like it was breathing a lot free er! No more heat on the right elbow! (472deg on that cat)
    I got the 2-5/8" torque plates from Kevin @ DK. Mounted them 2" in from the low slant (the sweet spot) and wow couldn't believe the power increase. A deeper rumble and still plenty loud but not as
    Obnoxious as the straight thru! We are 50 miles north of the Mexican Border on 5 acre lots and most run loud exhaust!
    I put a 606 air cleaner with external breather with another nice boost and later I added the FP3 tuner from Vance and Hines and got another big power boost! Very few bikes around here run the cat!
    It's 98.5 deg. right now! If we don't go crazy fast I get 38 to 42 MPG. Cruising 65 to 70 thru Colorado Highway 71 to Sturgis 40 to 42MPG!
  1. The cat got gutted today
    By Traveler in forum Harley Trike Conversions
    Last Post: 12-30-2011, 02:33 PM
  2. The cat has gotten to annoying
    Last Post: 06-27-2011, 06:10 PM
  3. No more cat converter!
    By chiefbuc in forum General Discussion
    Last Post: 02-21-2011, 05:44 AM
  4. Our Cat has to share Breakfast every mornin'....
    Last Post: 08-11-2010, 11:10 PM
