Likes Likes:  7
Results 1 to 15 of 15
Thread: Bummer!
    100+ Posts Ben_D's Avatar
    Dec 2018
    Phoenix, AZ USA
    Default Bummer!
    I led a 350 mile ride two months ago, and was almost home when I downshifted into a turn and tried to accelerate, but only crawled. Thought the clutch was gone, so I replaced with all new Barnett set, plus pressure plate and spring. Guess what? Same behavior as before. Ended up taking it back to the shop that did the conversion and was told there was a problem with the jack shaft and maybe more. Hopefully, it’ll be fixed before fall riding weather returns to AZ.
    2012 Victory XCT with CSC Ventura kit. Lloydz air filter, adjustable timing wheel, and HOH-1cams, Power Commander 5.
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Ben_D View Post
    Sure takes the fun out of summer Ouch! Fred
    250+ Posts Iowavicrider's Avatar
    Aug 2017
    Scranton,Iowa,USA
    Never heard of such a thing!
    Dec 2018
    Phoenix, AZ USA
    Quote Originally Posted by Iowavicrider View Post
    Factory rep said this was only the fourth one he’s heard of.
    Aug 2017
    Scranton,Iowa,USA
    We had a timing belt on the rear jug skip a link this spring, also a rare occurrence on the Victory’s. Our mechanic fixed it pretty quickly and we headed out to the Badlands with no problems for the long hot trip. I guess being Victory riders isn’t all sunshine and roses (but pretty dang close to perfect!).
    Dec 2018
    Phoenix, AZ USA
Size:  33.6 KBName:  D61A41DE-BC57-4189-A83A-FDDAA30C41CB.jpeg
    The jack shaft pulley was improperly heat treated and the inner splines stripped out. Waiting for new parts, now.
    Aug 2017
    Scranton,Iowa,USA
    Wow! A defective part. Were there any early signs of the problem that you noticed?
    That happened to quite a few Can-Am Spyder's early on.[08/09]....Factory Specs were Way too tight for the drive belt....
    Dec 2018
    Phoenix, AZ USA
    None whatsoever. I was nearing home after a 350 mile ride, downshifted into a turn, and when I tried to accelerate, the engine revved, but I couldn’t go more than 5mph. I felt sure it was the clutch.
    Thats the way it was with my Spyder [08]...Made a left turn out of a light shifted into 2Th. and the engine just revved...Thought it was the cluch also...
    4750+ Posts
    Mar 2015
    Texas
    I want to say thank you to you early pioneers. By the time we got my wife's 012 RT tourer, those problems were already corrected.
    American Legion Rider
    30+ Posts Alansut's Avatar
    Apr 2012
    Bronkhorstspruit South Africa
    Ben, has the new one been tested for hardness, it could be the same as the original.
    Dec 2018
    Phoenix, AZ USA
    Quote Originally Posted by Alansut View Post
    Well, I sure hope so! I’m waiting for the new sprocket to arrive from the factory. If it happens again, I will be very pissed!
    You're welcome.....I did a lot of R and D on my 08 Spyder for Bombardier on my dime's $$......I fixed a lot of the problems caveman style ....Like the air box filling up with oil, So common was the problem that the air box was nicknamed Oil-Box....Did that fix with a porous sponge the size of a sugar cube......
    Dec 2018
    Phoenix, AZ USA
    UPDATE! My trike and I are back on the road! Thank you CSC for the prompt shipping of my sprocket and retaining hardware! Also, thanks to Dave Bierman of Southwest Trike Center!
  1. O Hum, what a bummer..
    By DblTrbl in forum General Discussion
    Last Post: 03-10-2018, 11:48 AM
  2. Good friends are leaving ( Bummer )
    By Rollin Thunder in forum General Discussion
    Last Post: 05-06-2015, 10:54 AM
