Likes Likes:  0
Results 1 to 20 of 20
Thread: Front Wheel Shimmy
    10+ Posts
    Oct 2011
    Carrollton, Ga
    Default Front Wheel Shimmy
    My new to me 05 w/MT conversion had 11k miles when I purchased. Noticed on ride home it had a bad shimmy around 57mph. Front tire cupped bad so replaced with Pilot rear reversed on front. Had dealer service bike at same time. Added DynaBeads to all tires in hope it would solve problem. Seems to be not nearly as bad but it is still quite bothersome to me. It starts around 60mph and dissipates around 65 to 70 mph. Dealer could not find anything wrong. suggests I get rear tires checked for balance and roundness. He thinks it is transferring from a rear tire.
    Anyone have a similar problem in the past? I ride my neighbors trike and it is as smooth as glass at those speeds.<br />
    Any help will be appreciated.<img src="images/smilies/shrug.gif" border="0" alt="" title="Shrug" class="inlineimg" />
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: Front Wheel Shimmy
    Check the steering neck bearing for tightness. Needs to be tighter then a 2 wheeler.
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Bugsplat49</strong>
    <a href="showthread.php?p=96212#post96212" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">My new to me 05 w/MT conversion had 11k miles when I purchased. Noticed on ride home it had a bad shimmy around 57mph. Front tire cupped bad so replaced with Pilot rear reversed on front. Had dealer service bike at same time. Added DynaBeads to all tires in hope it would solve problem. Seems to be not nearly as bad but it is still quite bothersome to me. It starts around 60mph and dissipates around 65 to 70 mph. Dealer could not find anything wrong. suggests I get rear tires checked for balance and roundness. He thinks it is transferring from a rear tire.
    Any help will be appreciated.<img src="images/smilies/shrug.gif" border="0" alt="" title="Shrug" class="inlineimg" /></div>
    </div>
    </div>
    </div>I think your dealer is on the right track. Steering head bearings usually manifest as head shake in the vicinity of 40 mph. My MT also has some shimmy or vibration about the speed yours does. After I lubed the U-Joints the other day I ran the bike with the rear wheels off the ground. I did notice a little rear wheel hop and that just might be the problem.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    350+ Posts Woolie's Avatar
    Jun 2011
    Lubbock, TX
    most front end shake problems are at low speed, it could be a balance problem.
    2009 Honda Gold Wing Motor Trike Adventure Kit
    40+ Posts Marty's Avatar
    Jan 2012
    Williams Lake British Columbia Canada
    do above checks and check rear wheel bearings as well as wheel alignment on rear, toe inshould be 0. and check rear axle to front steering shaft at center should be same side to side.
  6. #6
    10+ Posts
    Oct 2011
    Carrollton, Ga
    Thanks to everyone for suggestions. Will have trike checked out again this weekend.
  7. #7
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Front tire pressure. Should. Be. 41 rear around 20
  8. #8
    10+ Posts
    Oct 2011
    Carrollton, Ga
    I am running with 42 psi front and 24psi rear.
  9. #9
    10+ Posts Sarge's Avatar
    Mar 2010
    Williamston, SC USA
    4.5 rake,Centramatic balancers, roller bearings in the neck and "full monty" traxxion fork overhaul did the trick for me. Except for the crown in the road it goes straight with no vibration or cupping of the tire. It's a little pricey to have it all done but if you do any kind of riding it is well worth the investment.
  10. #10
    10+ Posts
    Oct 2011
    Carrollton, Ga
    Ouch !! I certainly hope I don't have to go through that expense to get rid of a shimmy in the front tire.<br />
    <br />
    Has anyone used 'Bar Snakes',' lead shot' or even 'BB's' in the handle bars with any success?
  11. #11
    May 2011
    San Angelo
    Quote Originally Posted by Bugsplat49 View Post
    Ya Know, it just occurred to me. We know you have an '05 but I only guessed it to be a GL1800. If it is I don't think any or the weights you speak of will be usable. I'd be willing to bet you will end up finding the shimmy is caused by the drive train or rear wheels.
    Keep us posted please.
  12. #12
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Quote Originally Posted by Gorilla View Post
    Definetly do this since You removed the cupped tire and it got "better".....
    ..if it has WHEELS, I'm in...ThumbUp
  13. #13
    100+ Posts
    Dec 2010
    Finestrat. alicante. Spain
    Have you thought of a seeley steering damper? They really do help where any steering problem arises.
  14. #14
    10+ Posts
    Oct 2011
    Carrollton, Ga
    Anyone have a pic. of one? Installed would be best.
  15. #15
    1+ Posts
    Dec 2011
    Chas. WV
    Check an see if the bottom bolts on your ladder bars are tight.
  16. #16
    1+ Posts
    Feb 2012
    Titusville, FL USA
    I have the exact problem with my trike. It has the MT conversion. Speeds below 55 there is no shimmy. Between 60 & 70 there is a noticeable shimmy. Smooths out above 70. Front tire has 6k miles on it with no apparent cupping. Put 2 oz. of ceramic beads in front tire and had tire balanced. Helped some but did not eliminate problem. Been told to put front tire on backwards or get bias ply tire. Haven't done this yet. Still looking for a solution.
  17. #17
    10+ Posts
    Oct 2011
    Carrollton, Ga
    I have a new (Rear) pilot installed backwards on mine and it has the shimmy just as you described.
  18. #18
    30+ Posts
    Dec 2013
    Polson,Montana
    Default my experiense with MT
    Years ago, I had a Motor Trike that did the same thing. After a month of changing tires, balancing to no affect, I finally found out that one wheel was seriously out of round. Once found MT sent me a new one free. It's easy enough to prove if it's round or not. After that was changed out the trike went another 100K with no problem .
  19. #19
    1+ Posts
    Jun 2020
    Maricopa AZ 86138
    Default Front end shimmy
    I have a 2010 Tri Glide, never noticed a shimmy until I got it serviced, now at low speed I can get a shimmy, tire pressures were changed to normal pressure and shocks as well, I have heard 40 in the front and 20 in the rear is typical, I haven’t changed the pressure yet but I think I’m gonna
  20. #20
    1+ Posts
    Jun 2020
    Maricopa AZ 86138
    I have a 2010 tri glide, never noticed a shimmy until I had it serviced and they changed tire pressure as well as shocks, now at low speeds it will shimmy at times but get some speed up and it goes away, I’ve heard 40 psi in front and 20 in rear is best for a trike, I’m going to drop the pressure in the rear first, my shocks are at 30 psi, it does make sence. As it would change the rake a degree or 2
  1. Front Wheel Shimmy
    By 87Trike1200 in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-16-2019, 08:08 PM
  2. Front Wheel--Rear Wheel
    By drumdoctor in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-06-2015, 12:45 PM
  3. Front wheel shimmy?
    By Big_Steve in forum General Discussion
    Last Post: 06-05-2010, 11:08 PM
