Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: 06 Twin Cam 120" Build (Lots of Pictures)
  1. #21
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Default Re: 06 Twin Cam 120" Build (Lots of Pictures)
    MAybe because of engine harmonics..cuts down on vibration to the camshaft??
    One thing I can say is this engine is one of the smoothest I've ridden little to no vibration, the more I ride it the more I like it. Power is on tap anytime you twist the throttle just the slightest, its got nice low end. The compensator's whole function in life is to protect the output side of the crank, it is meant to keep from twisting it.
  2. #22
    May 2013
    Home
    Quote Originally Posted by msocko3 View Post
    With increased engine displacement and power a larger throttle body and bigger injectors is needed. This is a Horse Power Inc 55mm equipped with their 5.3gps injectors.
    I've been running the Doherty power pacc air cleaner system for quite some time, its a nice piece.
    A builder recommended that I use a 55mm throttle body for the work I am planning to do to the engine. I found this thread from a Google search and had a couple of quuestions.
    Was there any issues using the Doherty Power Pacc with the larger throttle body? Did you make any modifications to the Doherty Power Pacc prior to installing it or was it a direct bolt on?
  3. #23
    Sep 2009
    NE Ohio
    Quote Originally Posted by FLSTFI View Post
    No issues at all and no modifications, but then I'm using a 55mm from HPI which accepts stock sized air cleaner back plates.
  1. Replies: 3
    Last Post: 04-03-2013, 03:11 AM
  2. Mobil one "V Twin" oil
    By Lakeman in forum General Discussion
    Last Post: 04-17-2012, 06:07 PM
  3. Ride to "Archies" on Hutchinson Island in Moving Pictures... Enjoy!!!
    By mpolissky in forum Other Rallies & Rides
    Last Post: 02-04-2012, 03:07 PM
  4. Prototype build pictures
    By Popeye2347 in forum VW Powered Trikes
    Last Post: 04-01-2011, 06:30 PM
  5. Lots of extras
    By 01winger in forum Accessories
    Last Post: 12-13-2010, 09:23 AM
