Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 101 to 104 of 104
Thread: Front tire?
  1. #101
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Default Re: need new front tire
    The is the key :
    1) use a rear tire the same size that you removed from the front rim.
    2) use a bias ply tire only.
    3 mounting direction suggested is reverse mounting, this is an opinion
    Some do some don't,
    4) Any brand rear bias ply tire works better than the original radial
  2. #102
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    I like the BT45 also. Smoother riding and less noise than the MPA. Also if you put the 2 next to each other the BT45 has more girth and looks like a front tire on a trike should look. The MPA looks anemic next to the BT45.
  3. #103
    Contributing Member
    Sep 2010
    Wartrace,Tn.,USA
    tires are a matter of personal preference...I've got an 03-1800 bought used in 05..with 26,141 miles..Now,it has 121,500 miles and just last month got it's 5thMichelon Pilot Activa..With an ave. like that,I'd never reccomend anything else..I've been told by Skuuter, that I go a little too far but so far so good
  4. #104
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Quote Originally Posted by tommy loso View Post
  1. Front Tire
    By RRSCOTT in forum Honda Trikes
    Last Post: 06-22-2013, 12:17 PM
  2. Car Tire on the front?
    By Strat in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2011, 09:06 AM
  3. Front tire
    By Smoken'JOE in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-03-2011, 07:30 PM
  4. Front Tire
    By subeetrikerdon in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-16-2010, 11:22 PM
  5. Front Tire
    By Ron58 in forum Harley Trike Conversions
    Last Post: 07-26-2009, 10:10 PM
