Results 1 to 4 of 4
Thread: Lehman Monarch II rear shock actuator
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Default Lehman Monarch II rear shock actuator
    I noticed pulling into the garage that I lost some ground clearance. My rear shock pump doesnt start to labor until it reaches number 9 on the scale. Any suggestions or tips as to how I can get to the pump buried inside the body?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Default Re: Lehman Monarch II rear shock actuator
    Quote Originally Posted by Mick View Post
    Mick,
    Lower the suspension to ZERO. Disconnect the battery for about 10 minutes and see if the computer will reset. Disconnect the negative terminal first and the positive terminal second. When reconnecting, connect the positive first. See if that will cure it. There are 3 relays that operate the rear preload but it sounds like they are all working and the control panel switches on the left side below the pocket also sound like they are responding. Did you recently jump start this trike ????
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2008
    Midwest
    Jim when you go to use the preload you can hear the pump start at zero but when it gets to 9 you can here the pump start to labor and then its consistent until it reaches 25. And now entering the garage I have a 5 ft apron with an up angle along with a 2 inch step into the garage. Lately Ive been catching the chassis getting into the garage ,where before Ive never had an issue with height. To me at least the pump is acting like the hose is stretched and the pump needs topping off. And Im not getting full preload on the spring unit.
    Feb 2008
    Midwest
    Just a big shout out ot Steve at TRIKEZONE for his assistance and help with this. Steve you're a gentleman and scholar 1st class!
  1. Rear tire sizes for gl1800 lehman monarch ii trike
    By Motogordo in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2016, 10:23 AM
  2. Germany need your help, Lehman Monarch
    By ramon in forum Lehman Trike
    Last Post: 11-24-2012, 07:47 PM
  3. Lehman Trikes Monarch II
    By cincydude in forum Honda Trikes
    Last Post: 10-03-2012, 05:16 AM
  4. Lehman GL1800 Monarch
    By DeerWrangler in forum Honda Trikes
    Last Post: 12-14-2011, 09:06 PM
  5. Lehman Monarch II rear suspension
    By bette in forum Lehman Trike
    Last Post: 10-07-2010, 10:22 PM
