Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  0
Results 1 to 11 of 11
Thread: leaking oil
    90+ Posts
    Mar 2012
    Osage Beach, MO. USA
    Default leaking oil
    I took the Roadhawk for a good 200 mile drive. 100 miles to KC Royals Kauffman Stadium and 100 miles back.
    I parked the trike, and the next morning I had some big oil leaks under the motor. It only happens when I ride 70 plus.
    Is there a breather problem or outlet I need to know about. It doesn't appear to be a "gasket" type leak.
    I thought I would ask the much smarter VW gurus on the forum. Thnx for the help.
    2 bb
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: leaking oil
    Is your Roadhawk automatic or 4 speed? If automatic what color is the oil under the motor?
    90+ Posts
    Mar 2012
    It is an automatic. A friend thought it was tranny fluid, as it was darker than the engine oil.
    It also had blown over the back of the motor and cylinder covers, which in turn eventually gathered on location, and dropped to the floor.
    I have it at a VW "expert" as they say,and he is supposed to get back with me tomorrow, but I sure appreciate any suggestions or comments.
    thnx
    2 bb
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Sounds like it is gear box oil, on top of the trannie under the fake cover[held in place by 1 large bolt] there is 2 vents for the trannie to breathe , 1 for trannie fluid in rear of trannie[red oil] and the other is for the gearbox oil[black or dark brown] If the seal between the 2 parts of the trannie go bad, it let oil into the gearbox and overfills and goes out the breater hole on top, just my guest as to why the oil all over the motor and all,<br />
    Let us know what the VW expert says,<br />
    VW
    90+ Posts
    Mar 2012
    They checked the breathers, and all was good. I believe they said a pulley seal had gone bad, and they were getting one in. I'll know more Monday, thanks for the input.
    2bb
  6. #6
    10+ Posts
    Oct 2011
    Grand Junction Co.
    Which breathers were checked? The engine breathers or the transmission breathers? If they were looking for an engine leak, they would look at the engine breathers. I am concerned that they did not check the tranny breathers.
    VWmaqniac has a very good point. As a twenty plus year aircraft mecanic, who has maintained my own VWs, as well as my extended family's, I will concour with VWmaniac. Check the seal in the tranny.
    For your sake, I hope that they are correct and your problem is fixed. I would test it very soon after I got it back from the shop. That way if you need to have them do some warrenty work, they cannot say that it happened after their repair.
  7. #7
    90+ Posts
    Mar 2012
    Thanx for the help and input. It was a custom pulley seal that went out. Have one ordered and should be here in just a day or two. it was actually dripping oil from that location.
    2 bb
  8. #8
    Jul 2011
    Gresham,Ga. usa
    Custom pulley seal?? There are only 1 seals on a VW Motor, the rear main seal, which in your case would be behind the flex plate and on the trannie in the same are, the torque converter seal which the converter goes onto in the trannie nose,
    Man, I sure hope them guys know what they are doing for your sake, smile, good luck
    Vw
  9. #9
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Quote Originally Posted by 2blackbelts View Post
    2 bb
    If it has a sand seal pulley are the valve covers vented?
  10. #10
    90+ Posts
    Mar 2012
    It was a Sand Seal I believe, as a custom one had to be ordered. The valve covers are vented. Went on a 50 mile trip at 80 and no oil leaks at all.
    Thnx for the input.
    2 bb
  11. #11
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Great! Sounds like it is set up correctly. Some of those aftermarket pulley and seal set ups dont last very long (pulley to soft and seal to thin). Ask the mech if the pulley was grooving at the contact point of the seal.
    Glad You are back in the wind.
    Enjoy the ride!
  1. Leaking Forks
    By pmascarenas in forum VW Powered Trikes
    Last Post: 05-18-2013, 07:05 PM
  2. oil cooler is leaking
    By greyfang in forum Harley Trike Conversions
    Last Post: 08-25-2012, 11:38 PM
  3. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  4. coolant leaking
    By Southern Man in forum Honda Trikes
    Last Post: 09-07-2011, 08:47 AM
  5. seals leaking
    By 01winger in forum Miscellaneous
    Last Post: 11-24-2010, 09:21 PM
