Results 1 to 20 of 24
Thread: HF 4x3 trailer Project
    300+ Posts
    Apr 2010
    Sterling, Colorado USA
    Default HF 4x3 trailer Project
    Hello
    Well last week I purchased a used HF trailer (Like new)
    Like the one here:
    40-1/2" x 48" Small Utility Trailer - 1090 Lb. Cargo Capacity
    Got some plywood for the floor and I wanted to use a canvas bag. Well today went out of town and found a cargo carrier for $40. Man it’s pretty big...
    It’s a karite voyager. Its 46x38x18. I think. Well for the price I could not pass it up... Got it home and checked to see how it would fit on the trailer...
    Just right.... Still working on getting rails done..... I would like to paint the
    cargo carrier a red/black color...
    Any suggestions on painting over that plastic material?
    See Pics:
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Default Re: HF 4x3 trailer Project
    The cheap spray bombs from where ever will work great on it and no sanding needed to mak it stick.
    VW
    300+ Posts
    Apr 2010
    Thanks for your response..
    I think overall I am a head of the game Trailer/carrier/wood material/ nuts & bolts/ ... At or about $300.00
    Still need to buy paint
    150+ Posts DanDolfn's Avatar
    Feb 2011
    Lake Placid, FL
    I bought the same kind of trailer from Northern Tool.
    A friend built a wooden box for me (I needed 20" high and couldn't find a container).
    But either way, this is a LOT cheaper than buying a pre-made trailer. They seem to run $1500 and up.
    [SIGPIC][/SIGPIC]
    If you don't grow up by age 60, you don't have to....
    300+ Posts
    Apr 2010
    Hello
    Well I got one of my projects completed... I can use a canvas bag with this set up. Overall it came out ok... Mind u first time I ever done something like this.
    Added a two tier railing:
    After done painting:
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Great job!!!!! I just love trailers
    300+ Posts
    Apr 2010
    It looks better in the picture then in person
    TOI -Virginia KDHUFF's Avatar
    Feb 2010
    millboro, va
    they make that paint that you use on plastic lawn chairs I have used it before and it works as it says it will.
    Sep 2011
    You can also use regular automotive paint and use the plastic additive. I think it looks good the way it is.
    100+ Posts
    Dec 2011
    Mathias,WV Hardy
    For rattle can fans Rustoleum makes a primer just for plastic (I just bought a can)
    Good luck with it.
    Nice looking trailer!!
    Tip
    300+ Posts
    Apr 2010
    Thanks all....
    300+ Posts
    Apr 2010
    Hi All
    Well I just finished painting my cargo carrier... Let me say with one color it was good, but when I tried to do some trimming with some red paint it did not come out.. Had to repaint with black...Came out ok i though:
    Sep 2009
    Near Myrtle Beach SC
    Quote Originally Posted by bigjoey38 View Post
    Hi All
    If you want an idea to add some color to your carrier, how about using reflective pin striping to give yourself some color variance and additional reflectivity? Heres a link to a supplier who sells reflective pin stripping >>> Streetglo Reflective Tape. Reflective Pinstripe Pinstriping Installation Conspicuity tape
    Tom
    PS, Im going to copy your trailer and add mud flaps on my HF trailer
    300+ Posts
    Apr 2010
    Quote Originally Posted by FLTR2008TRIKE View Post
    Tom
    Thanks Tom... I was thinking about the pinstrip thing .... Thanks for the website
    300+ Posts
    Apr 2010
    Hello all
    I connected my trailer to the bike and when I turn on the turned signals my trailer blinks the opposite direction. When connected to my vehicle no problem.
    Sep 2009
    Sounds like your taps into the bike turn signal wiring are reversed.
    Tom
    80+ Posts viper's Avatar
    Aug 2011
    Terra Alta, WV. USA
    Great Idea! Going to make myself one! I like the cargo carrier idea! Thanks!
    300+ Posts
    Apr 2010
    Well since I have a three day weekend I decided to mess around with the trialer and got the lights now working correctly. So I headed out for a run with the bike and trailer ( first time) thru local rodes at 45 MPH tops. I tell you I though I did not even have the trailer back there at one point had to pull over and check. It ran pretty good. When I hit the 30 MPH with rough rodes I can hear the trailer but ran straight behind the bike. So Thinking of now putting on the cargo box to check things out.
  19. #19
    300+ Posts
    Apr 2010
    Well Had time today and added the Cargo carrier.
    What do u think rail or cargo Carrier?
  20. #20
    550+ Posts
    Feb 2012
    tupelo MS
    Looking good, ready to travel. Like the cargo box.
  1. Winter Project
    By SEABILL in forum Honda Trikes
    Last Post: 02-12-2014, 01:12 PM
  2. My latest project
    By Triker Ox in forum VW Powered Trikes
    Last Post: 01-14-2013, 11:33 AM
  3. My Trike project
    By Sacred Steel in forum General Discussion
    Last Post: 05-16-2011, 10:58 AM
  4. New Trike Project
    By JoJo in forum Honda Trikes
    Last Post: 08-14-2010, 11:35 AM
