Results 1 to 2 of 2
Thread: Tire DIAMETER
    1500+ Posts
    salt lake city, ut
    Default Tire DIAMETER
    Do any of you run taller tires on your trike?? Most 15 and 16 inch wheels have tires that are between 25.5" and 26.5 inches in height. I am using a 15 inch wheel-but in order to get whitewalls I had to get a taller tire which is 28.4 inches tall. I am worried that the taller tires will look funky on my roadking trike. The only advantage I can see to the taller tires is that it might provide more muffler clearance and put the back end 1.5 inches higher-these tires truly dwarf the front tire in the bike. Any feedback on this conundrum would be greatly appreciated-could end up being a 300.00 mistake as I cannot return the tires I bought on line!!
    Jul 2011
    Central Pa.
    Default Re: Tire DIAMETER
    Hi ABA i did my trike this past winter its a D.F.T. kit it calls for 16"rim around 25" tires also.. so i purchased 17"wheels and my tires are 26.9" for over all diam. i did this because my trikes is a1500 honda an on the interstates running 75to80 mph on trips the motor was rpming around 3750 or so. now at 75mph it rpms 3000 to 3100. it dont sound like ur running the daylights out of the motor. and tires an rims looks good to... if u stay at a 15" rim u will hv a lot of rubber showing under the fender a bigger diam rim will off set that look . but u have to make sure u have room for the tire to travel up&down with out hitting the fenders . i couldnt go any taller with the tire diam on my trike cause of tires hitting fenders. it can be done takes a little resreach... good luck
  1. New tire
    By howardg in forum Tires, Wheels, Brakes, Front End
    Last Post: 06-18-2013, 08:03 PM
  2. front rim diameter change?
    By mopar in forum Harley Trike Conversions
    Last Post: 11-29-2011, 01:31 PM
  3. Tire--HELP!!!
    Last Post: 10-07-2011, 10:45 PM
  4. What Tire to Get--HELP!!!
    Last Post: 07-28-2011, 08:20 PM
  5. Diameter of the Stallion Roll Bar
    By Switchback in forum Stallion Trikes
    Last Post: 09-18-2010, 07:45 PM
