Results 1 to 12 of 12
Thread: Fuel Pump
    300+ Posts
    Apr 2010
    Sterling, Colorado USA
    Default Fuel Pump
    Do you know what type of fuel pump can be used with the 1600 DP engine. I went out for a ride today and then had to pull over. Fuel not getting to the carb. Brother in law tinkered a bit with the fuel pump and got enough fuel to get home ( about 2 blocks) the trike stop running. He said he thinks the fuel pump is going out. Not enough fuel pumping. He took out the one I had in and it read it was a 12 v 5.5 -9 PSI..
    Does the PSI level sound right?
    70+ Posts
    Mar 2009
    Vale, NC USA
    Default Re: Fuel Pump
    What carb are you running? Does it have a fuel pressure regulator?
    Unless you are running an injected engine case that doesn't have the mounting for a stock fuel pump, I'd go back to stock. They are very dependable.
    In my experience, carbs used on VWs like 3-4 psi. Any more and you need a regulator to keep the pressure down. You may get by with a higher pressure, but it makes for more leaks and tuning problems especially with Solex carbs.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Webers are the same. 3.5psi
    I use a small electric and a regulator.
    300+ Posts
    Apr 2010
    Thanks for the Info.
    300+ Posts
    Apr 2010
    Well took the bike to a local mechanic and he was going to put in a mechanical pump but it did not have the rod. So he ended up putting in a 1-5.5 PSI fuel regulator. It was set at 5 when I picked it up and drove it home. I set it to 4.5. Ran around town for about 30 min..Shut down ran into store and came back out started right up. no issues.
    Before at the stop lights seems like it wanted to shutdown.
    He did adjust the carb and picked up the idle a bit.
    No issues now at the stop light.
    In the past I would stop somewhere... shut the engine off for a few while (5-10 min) then turn it on, but would be difficult to start. Felt and smell like alot of fuel in the carb area.
    300+ Posts
    Apr 2010
    Update:
    Well took the bike out today and rode the local rodes and interstate. What a diffrence. Locally in town at the stop lights engine ran fine. Did not feel like it wanted to shut off. Took it on the interstate and got it up to 72 MPH .. Could have got it up further but at that point did not want to take a chance. The regulator was set at 5.0 and I put it down to 4.5 ... Ran well... When I got home I put it at 4.0 so we will see over the week how it runs. Thanks for your help.
    I did feel some front wheel wobble so I am going to have it checked out.
    Maybe it needs a balance
    300+ Posts
    Apr 2010
    Took the bike out for a spin today. Goal was to set the fuel regulator from four to three and see how it runs. After about 1 hr riding aorund town and shuting off the bike a couple of times ( wanted to make sure it would start) it ran good on three. I think I will keep it there..
    I have a light that comes on after awhile running around but not sure what the light is for. When the bike is warm it turns on when I am at a stop light. If I put it in nutral and/or start going again it goes away. The bike does not feel like it wants to shut off... It feels way better then before. I wanted to get the engine running just right before I do the longer trips.
    Now the next thing will be the forks and the tire... I really want to replace the tire anyway since it does have some small craks in it anyway.
    TOI - Oregon champsman97045's Avatar
    Jul 2010
    oregon city, or usa
    on my old vanagon the red lite only came on when the engine got to a overheating condition , check your air intakes to the fan for junk which will cause reduced air flow
    Life is short, Break the rules, Forgive quickly, Kiss slowly, Love truly, Laugh uncontrollably, And never regret anything that made you smile.
    70+ Posts
    Mar 2009
    Vale, NC USA
    Joey, most likely, that light is an oil pressure or charge light. You need to trace out the wiring and figure out what the idiot lights are for. With the ignition switch on, remove the wire from the oil pressure sender and ground it. That should energize the oil warning light. You can remove the wire from pin 61 from the voltage regulator and ground that wire to check for a charging light.
    If you have you're idle set too low, it can cause either of these lamps to light. Once you figure out the lights, then you can figure out the problem.
    300+ Posts
    Apr 2010
    Thanks for the tip.
    Joe
    20+ Posts rbourne3's Avatar
    Jul 2010
    Fernandina Beach, FL
    The oil pressure light coming on at a stop is not a problem. VW's have very low pressure at idle. The light is often hooked to both the alternator and oil pressure. If either come on, stop immediately. Throwing a belt can blow a motor in almost no time.
    300+ Posts
    Apr 2010
    Thanks again!
  1. What fuel? Anyone ever use Aviation fuel?
    By hazel in forum Harley Trike Conversions
    Last Post: 09-06-2023, 10:14 PM
  2. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  3. Gas pump shutoff?
    By jimdog1356 in forum Harley Trike Conversions
    Last Post: 04-25-2012, 02:04 PM
  4. Fuel Pac vs TTS
    By VaThumper in forum Harley Trike Conversions
    Last Post: 02-26-2012, 04:15 AM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
