Results 1 to 6 of 6
Thread: Running boards vs engine cooling
    100+ Posts pigbike's Avatar
    Apr 2012
    Odessa, Florida
    Default Running boards vs engine cooling
    Does anyone know if running boards will cause the engine to run hotter then without them.
    I have heard they might, so just checking to see if someone has the answer.
    100+ Posts
    Pahrump NV
    Default Re: Running boards vs engine cooling
    The temp gage didn't move a bit..............it's water cool
    Hisst
    If u are burnin gas an killin bugs........u must be havin a good time
    20+ Posts
    Oct 2010
    CT, USA
    Didn't notice any big difference...Love 'em!
    200+ Posts THEREALTRIKKY's Avatar
    Dec 2011
    Tyler, TX
    Also, what engine, exhaust, and computer upgrade (if any) are you running. If I had to guess, I'd say you probably have a 110 engine with a rear cylinder heat problem. This can be an issue with those engines..
    Apr 2012
    Odessa, Florida
    My trike is a 2005 Harley Ultra with 95" big bore kit, and a power commander.
    I have never had the lowers installed. I also don't have a running hot condition, but do not want one. If the lowers are installed I don't know if that would cut down the air flow or not. As it's either warm or hot here, I don't know if installing them is a good idea.
    200+ Posts
    Jun 2009
    Darlington
    I have the running boards and love them, did not notice any effect on the heat..........
  1. Running boards....
    By eighty80 in forum Harley Trike Conversions
    Last Post: 03-10-2013, 07:48 AM
  2. running boards
    By Ellard in forum Harley Trike Conversions
    Last Post: 05-11-2012, 10:39 PM
  3. Lehman Running Boards
    By rgc in forum Harley Trike Conversions
    Last Post: 04-21-2011, 12:25 PM
  4. Tri Glide Running Boards
    By trikermutha in forum Harley Tri Glide
    Last Post: 03-29-2011, 01:20 PM
  5. New Running Boards are selling well!
    By trikermary in forum Harley Trike Conversions
    Last Post: 02-22-2011, 08:14 PM
