Results 1 to 9 of 9
Thread: Rattle 05 RK Motor Trike conversion.
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    Default Rattle 05 RK Motor Trike conversion.
    My wife's Road King conversion has a rattle that sounds like it is coming from the right brake drum and when I step on the rear brake it stops. I have taken it apart and there is nothing loose nor does anything look wrong with it. I tried adjusting it but it did not help. The brake pedal it not loose either. Any ideas ???<br />
    <br />
    Thanks SR
    100+ Posts pigbike's Avatar
    Apr 2012
    Odessa, Florida
    Default Re: Rattle 05 RK Motor Trike conversion.
    Do you have a parking brake? Might be something there making noise. If there is something loose in the brake drum you better take it apart before it destroys something, or you loose the brakes on one side.
    any chance the problem is on the other side and you just hear it on the right?
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    I have had it apart on both sides it all looks good. I have been all over it top and bottom and can't find it.
    Thanks a lot,
    SR
    Oct 2010
    USA
    how about the body of the trike?? or the mufflers??
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    Checked all that. Thanks
    150+ Posts bullet 10's Avatar
    Oct 2010
    climax springs,MO
    Check the rear muffler rubber holding the muffler up where the two bolts are.
    ttom, wife and triglide:clan:
    Sep 2009
    Near Myrtle Beach SC
    Quote Originally Posted by bullet 10 View Post
    +1 The rubber isolator may have moved enough the muffler tab is against the tab mount on the frame. The older isolators are short and can move out of position. Harley came out with a longer rubber isolator for the muffler mounts in 2009 that eliminates the problem
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    Thanks Guy's . That's one of the first things I checked as that has happened to me before.<br />
    I am going out this morning and see what I might find I will keep you posted.<br />
    <br />
    SR
  1. Need Help With Rattle in GL 1500 Motor Trike
    By Colorado Con in forum Honda Trikes
    Last Post: 12-01-2013, 01:40 PM
  2. Motor Trike Announces New IRS Conversion for F6B
    By Motor Trike in forum General Discussion
    Last Post: 03-08-2013, 05:53 PM
  3. Motor Trike Vibration/Rattle
    By Mr.Wizard in forum Harley Trike Conversions
    Last Post: 05-25-2009, 07:03 PM
