Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 40 of 90
Thread: Tire Pressure Thread
  1. #21
    TOI - Scotland The Wolf's Avatar
    Mar 2008
    Livingston Scotland
    Default Re: Rear tire pressure on all trikes
    I run 41 on the front and 21 on the back of my motortrike 1800. This seems to work well on the crappy roads over here,especially after taking a pounding this winter:eek:
    KelticWings Scotland.
    www.kelticwings2.webspace.virginmedia.com
    :jerry:
  2. #22
    300+ Posts Calman's Avatar
    Jun 2009
    Whortonsville, NC
    Default Rear tire pressure
    The 750 Shadow runs 41 pounds in the front and 23-24 pounds in the rear.
  3. #23
    40 in front 22 in rears
  4. #24
    TOI - Washington Triker Mike's Avatar
    Jun 2009
    Bridgeport,Wa.
    Thanks for all the input.I understand the crown theory but I think what he told me was wwaayy overkill..I carry 41 front & 23 rear on an 96 Se roadsmith
  5. #25
    40# in the front MPA mounted backwards
    24# in both rears
    20,000 miles and they all look brand new!!
  6. #26
    Contributing Member Puff's Avatar
    Feb 2010
    Melbourne,Victoria,Australia
    Very interesting thread this one, particularly the variations in each individuals preference. Personally, I've found a 'happy medium' of 15 psi in both rear (I personally think odd pressures in the rear tires are a waste of time) and around 30 psi in the front... seems to work okay for me.
    When I first took the trike to the road for it's 'maiden run' last August, I had way too much in the rear tires and the ride was atrocious. After experimenting with various pressures and shocker settings, the above seems to give me the best ride.
    :wave4:I don't suffer from insanity; I enjoy every minute of it
  7. #27
    80+ Posts cmore's Avatar
    Mar 2010
    North West TN
    On my CSC, I put 40-41 in the front and 26 in both rears.:2cents:
  8. #28
    We suggest to all our Trike customers that the rear is 18-24lbs. and the front is 41lbs.
  9. #29
    150+ Posts KRUZR's Avatar
    Oct 2010
    Aurora, IL, USA
    Default Front Tire Air Pressure
    There have been a lot of opinions in this forum regarding recommended air pressure in the tires both front and back. The weather here in Northern Illinois hasn't been very good for riding but I've managed about 800 miles so far on my new Street Glide/CSC Trike. And until today and about 250 miles today I've had 40 psi in the front Dunlap 402 and the CSC recommended 28 psi in the rears. The pressure in the rears is just fine but where the heck did the recommendations for 40 or 41 psi in the front tires come from. I'm going to need two Rotator Cuff operations if I continue using 40 psi. Guess I'll drop down to 38 and see if there is a difference. I've also had installed the CSC Power Trak. No wobble at all in the front and I'm impressed with the CSC IRS. This sunspenion is doing a good job of protecting my back. Really, one of the reasons I thought I would convert to a TRIKE, Ride Safe
  10. #30
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Default Re: Front Tire Air Pressure
    The HD trikes use 36 front.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
  11. #31
    I run 40 up front with no issue.
  12. #32
    Jun 2010
    Indianapolis, In.
    The 40/41 seems to have evolved from findings of tire cupping at lesser pressures.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  13. #33
    1+ Posts hot wheels's Avatar
    Dec 2010
    lady lake, florida, usa
    I run 42 lbs in front also
  14. #34
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Even with the Pilot Activ Tire on the Front, Traction, Ride, etc. is Great in the Mid-30s Pressures..."but"...I found really accelerated Cupping, and Centerline Flat Shaping.....so far, Tire Life seems to be better with the 40-42 lbs Pressures. I just started ridin' my second Pilot Activ.....New data coming later with New, Higher Pressures.....
  15. #35
    Oct 2010
    Aurora, IL, USA
    Thanks for the input. We spent the day riding the beautiful secondary roads of South Central Wisconsin, that's probably why I noticed it so much the last time out. Tire wear is a great reason to keep the tire aired up. I'm going to try it at 38 psi and keep an eye on it. Ride Safe!
  16. #36
    1500+ Posts
    Sep 2009
    North East Ohio
    I run 36 lbs in my front tire. Have had no issues with it.
  17. #37
    Mar 2010
    North West TN
    Try to keep front Pilot Activ Tire at 39-41lbs and rears 25-26lbs.
    CSC kit
  18. #38
    10+ Posts falcon1's Avatar
    May 2011
    Round Rock, TX, USA
    I have been running an MPA since I Hanniganized 20k miles ago. I run 41 psi (cold) in it and it is now about half tread with little cupping and getting more and more a flat profile. Looks like I will get 30k+ before I change it.
    FYI, I have a TireGard system monitoring the three pressures. After riding a few hours on a hot day the front pressure rises to about 46/47 whereas the rear tires rise from 26 only 1/2 psi.
    Stu McCurdy, Round Rock, TX
    2009 Goldwing/Hannigan Limited Edition
    2002 Escapade Trailer
    [SIGPIC][/SIGPIC]
  19. #39
    30+ Posts
    May 2011
    Upstate,SC USA
    Good thread.I'll keeps this in mind when I start to build.My current two wheeler runs 33/36 solo and 33/41 duo.I was planning to stick with 33 for my front tire but after reading this I think I'll run the max psi on the tire side wall,40 psi.
    1989 Suzuki GS500R Custom Built By Myself
    1990 Suzuki GS500E Future Custom "Tite Trike"
    1992 Suzuki GS500E under going resto
    1992 Suzuki GS500E Waiting For Resto
    MANIC CYCLES->MY PERSONAL BLOG.
    MANIC CYCLES->MY PERSONAL FACEBOOK PAGE.
  20. #40
    30+ Posts
    May 2011
    Napoleonville, La
    I run 38 front and 25 rear on my 95 FLHTC with no problems. Looks like I can get at least 30,000 out of the front and "who knows" out of the back Firestone's. Great miliage so far.
  1. Tow Pac tire pressure
    By DanB in forum Outrigger Style Trikes
    Last Post: 07-12-2014, 07:48 PM
  2. mpg/tire pressure
    By geraldlanc in forum Honda Trikes
    Last Post: 01-05-2012, 02:43 PM
  3. Tire Pressure
    By rickt in forum Honda Trikes
    Last Post: 11-23-2010, 08:09 AM
  4. tire pressure
    By oldmanonavtx in forum Outrigger Style Trikes
    Last Post: 09-10-2010, 06:51 PM
  5. Tire pressure
    By 1852cc in forum Harley Trike Conversions
    Last Post: 06-06-2010, 11:37 AM
