Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 41 to 60 of 90
Thread: Tire Pressure Thread
  1. #41
    Dec 2010
    Madisonville, KY
    Default Re: Front Tire Air Pressure
    Falcon1 noted that his 41 psi was at cold. No one else has remarked whether they measure at hot or cold. Please advise. It seems to me that my roadsmith was riding rough at 41 psi (cold). After riding 50 miles in 94 degree weather, I measured the psi and came up with 46. I lowered the presure to 40 (hot) and received a much better ride coming home. Is this just me??? Also will the tire start cupping at 40 psi (hot)
    Thanks for the imput.
  2. #42
    30+ Posts
    May 2011
    Upstate,SC USA
    Quote Originally Posted by david1144 View Post
    My tires state cold temps,so I check at cold temps before riding/driving.
    1989 Suzuki GS500R Custom Built By Myself
    1990 Suzuki GS500E Future Custom "Tite Trike"
    1992 Suzuki GS500E under going resto
    1992 Suzuki GS500E Waiting For Resto
    MANIC CYCLES->MY PERSONAL BLOG.
    MANIC CYCLES->MY PERSONAL FACEBOOK PAGE.
  3. #43
    Contrinuting Member
    Apr 2009
    greenfield indiana
    I have a 96 1500 with a 06 lehman kit,I run 38 front and 20 rear seems to work good for me,try them settings and see how it rides.
    :yes::yes::yes:
  4. #44
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    I'm "experimenting" right now with 42 Cold....Hot gain yesterday after an hour of ridin' twisties was at 44. Startin' to feel more "consistant" to me. Using around 39 in the past got Summertime Hot gains of sometimes 45-47. The higher pressure seems to be cooling the tire better for less overall gains...Hopin' for less cupping too......."We'll See".....
  5. #45
    150+ Posts Rowdy's Avatar
    Dec 2008
    Western Kentucky
    My experience is that once a tire starts to cup it cannot be reversed. I would be very careful running the lower pressures especially with the Pilot Activ or BT45.
  6. #46
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Default REAR tire air pressure
    So what is the least amount of air pressure you can put in the rear tires. I ran into a guy tonight running a Frankenstein kit on a Small Harley. He is running 23 # in the rear and it rides like a truck. I told him to drop the pressure. How far can he go. 14# or lower. He is a member. hope he see this and chimes in . NANA how low can you go with your rear tires
  7. #47
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Default Re: REAR tire air pressure
    John I keep mine at 17-18 psi. I've had it down to 16 without problem, but below that it begins to feel too soft. If I have mine over 20 psi, it is way too rough for comfort. Note that I don't weigh a lot and I ride solo.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
  8. #48
    TOI - Scotland The Wolf's Avatar
    Mar 2008
    Livingston Scotland
    Default Tyre pressures?????
    Hello boys & girls... I know this topic has probably been thrashed to death but I have left it too late to go hunting around
    What is the average tyre pressures for the goldwing 1800 Front and Rear. I am running at the moment 21 at the back and 41 at the front. I have done this for years without problems but one of our club members tried this on his CSC (same pressures) but was non too happy with the ride
    So dig deep and post away
    KelticWings Scotland.
    www.kelticwings2.webspace.virginmedia.com
    :jerry:
  9. #49
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Default Re: Tyre pressures?????
    Yours works on my 90wing/motortrike.
  10. #50
    350+ Posts Woolie's Avatar
    Jun 2011
    Lubbock, TX
    My 09 owners manual manual says 36 in the front so I go with that and I have 25 in the rear tires. I had them at 20 but didn't like them that low. Mine is a Motortrike Adventure Kit.
  11. #51
    Sep 2011
    Newberry, FL USA
    I have been running 18 rear, and 41 front on my '05 gl1800 roadsmith conversion. I am new here and missed the other recommendations. What are the most often used pressures?
    Randall
  12. #52
    900+ Posts jtilmon's Avatar
    May 2011
    Collierville, TN USA
    Have 08 GW/ Roadsmith and run 41 front and 26 rear. drives and handles good. just spent 3 days in Smoky Mountains and it handled great in the curves and elevations changes.
  13. #53
    600+ Posts Saltywheels's Avatar
    Oct 2009
    Rancho Palos Verdes, CA
    Exactly the same on my 03GL / CSC. Has worked for 3 years now.
    You dont stop riding because you're getting old. You get old cause you stopped riding
  14. #54
    900+ Posts kwputt's Avatar
    Dec 2010
    Frankfort
    Wolf we have been running 38 front and 26 rear on our 06 GL 1800 CSC for the last 10K miles with no complaints. I think the rear would depend more on your two up weight.
  15. #55
    Mar 2011
    Boise Idaho
    Default rear tire pressure
    Hi all
    have a friend that just got a 1800 roadsmith but does not have a manual can you roadsmith owners give us an idea what you run for rear tire pressure? on our Champions we are running 18 to 25 depending on load with 15 inch wheels the roadsmith has 16 . and they were set at 35 witch seems high to me. thanks
  16. #56
    May 2011
    San Angelo
    Default Re: rear tire pressure
    I'd have a hard time believing Road Smith recommends that much air pressure. Motor Trike says 24 pounds. I think most of us bump that up to 26 or 27 but 35 is just too much....
    2015 GL1800/Roadsmith HTS1800
  17. #57
    Mar 2011
    mountain home,ar. USA
    I have an HT1800 with Kuhmo tires. Roadsmith told me to run 28-30 psi. After experimenting I found them on the money. I use 28 two-up on local rides and 30 when we're traveling fully loaded.
  18. #58
    Dec 2009
    LaFayette
    In Pearl (90SE Wing/Motortrike) I run 20 left-22right.RIDE SAFE
  19. #59
    I have Kellys on the back at 26-28 psi(no trailer vs trailer)
    MPA rear tire mounted in reverse on the front at 40 psi
  20. #60
    TOI - New England
    Mar 2008
    Conn
    Start at 22 and increase untill the ride gets stiff then drop Back 1 lb.
  1. Tow Pac tire pressure
    By DanB in forum Outrigger Style Trikes
    Last Post: 07-12-2014, 07:48 PM
  2. mpg/tire pressure
    By geraldlanc in forum Honda Trikes
    Last Post: 01-05-2012, 02:43 PM
  3. Tire Pressure
    By rickt in forum Honda Trikes
    Last Post: 11-23-2010, 08:09 AM
  4. tire pressure
    By oldmanonavtx in forum Outrigger Style Trikes
    Last Post: 09-10-2010, 06:51 PM
  5. Tire pressure
    By 1852cc in forum Harley Trike Conversions
    Last Post: 06-06-2010, 11:37 AM
