2012 Tri-Glide accessory plug
Apr 9, 2012
19
Billings, MT USA
My accessory plug(cig lighter) quite working and checked wires direct and no power. All electric items work. Checked for fuse and nothing is listed for this plug. Any ideas what this is hooked up to?:Shrug:
Has to be a fuse. Use a tester to find it. I would tell you which one but my 07 RK would be different. The fuses are easy to check with a volt meter. Good Luck
The accessory switch does not control the accessory plug. At least that is what the manual indicates. There is not any fuses marked "accessory".
Miker,
If you're referrng to the 12-volt power outlet that's in the lower left front fairing, power to that outlet is controlled by the fuse labeled "P & A". It will be a 15-amp fuse (blue). This fuse also controls power to pin 1 on the accessory connector plug under the seat (orange wire with red tracer).
It will also supply power to pin 3 of the accessory plug (orange wire, no tracer) when the ACC switch on the fairing is turned on (the switch should also illuminate).
CedarRonin
CedarRonin
