Results 1 to 20 of 22
Thread: Trike tow bar
    300+ Posts
    Apr 2010
    Sterling, Colorado USA
    Default Trike tow bar
    Has anyone seen this tow bar in use?
    Cornell Trikes Products
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Default Re: Trike tow bar
    I build them and have used mine for over 6 years, has been all over the USA and not a problem with it, just have to make sure you use good rachet tie downs in rear, or do as I do, use a small chin to secure it in the upright position and away you go,
    VW
    300+ Posts
    Apr 2010
    Thanks VW for the info
    5+ Posts skeeter's Avatar
    Jun 2012
    knoxville , tn , usa
    i was a vw tech in the 70s , be careful using a tow bar with the rear wheels on the ground . they will sometimes jump in gear .if you are using a big truck or a motorhome to pull it , you might not notice & blow the motor sky high. i rebuilt several because of that. i never had it happen to me , only costumers & i pulled tons of bugs in for repair ?? just a heads up.
    300+ Posts
    Apr 2010
    Thanks Skeeter!
    10+ Posts fatirossi's Avatar
    Sep 2011
    Montrose, Angus, Scotland
    Could always make a bracket to lock the gearstick into a neutral position. I'm going to attach a socket onto the gearchange shaft so that I can insert a rod through and lock it, just for trailering.
    80+ Posts classicfins's Avatar
    Feb 2011
    Ruston, La USA
    Does anyone have a photo of this setup in use? I'm still trying to figure out what keeps it off the ground....
    Doug Young
    Ruston, La
    Proud VW Trike Owner
    '86 Stallion built by Arizona Trikes
    Some people are like slinkies...
    Not much good for anything, but they sure are fun to push down the stairs...
    300+ Posts
    Apr 2010
    Doug
    Just sent you a PM.
    Feb 2011
    Ruston, La USA
    Thanks Joe!
    Quote Originally Posted by bigjoey38 View Post
    Doug
    Just sent you a PM.
    Doug Young
    Ruston, La
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Would a heavy duty one of these work??
    Motorcycle trailer carrier tow dolly hauler hitch rack | eBay
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    RSW:
    No, the solid type carriers as shown in the eBay advertisement work beautifully for two-wheelers, but the geometries of our trikes require a carrier that is hinged horizontally to keep stress from being generated in the front wheel/steering neck areas when turning corners. Since this is not a new subject to this trike forum, perhaps someone can refer us to a better explanation, or maybe even a diagram or two to better explain the problems encountered.
    Sep 2011
    Heres one we seen on a trip this spring. Think it was a solid type.
    Sep 2011
    Quote Originally Posted by Loner View Post
    RSW:
    Sometimes my thinking is a little slow, but understand what you are talking about. The stress on the neck would probably worsen the higher you lifted the front end. If you kept your receiver height low, wouldn’t that make the stress level lower? I think you would have more neck stress if the trikes rear wheels were unleveled. Maybe a deep pothole or running off the edge of the road. I think more of a swivel action would be needed then horizontal hinging. Or is the same thing. My need for one would just be to tow one home if I have a breakdown. This just hit me when I had to limp mine home with a ignition problem the other night.
    Aug 2010
    Harvest, AL USA
    Try this - set the front forks of your trike perfectly straight (front wheel will be perfectly vertical). Now turn the forks full-lock to the left and you''ll see that the front wheel leans quite a bit into the turning direction. The solid tow bars make a trike turn like that but try to hold the wheel perfectly vertical, therein making significant strain on the neck. Yes there are some of them out there on the road, but it's just a matter of time until they have some major problems such as broken or bent-spoke wheels, cracked frame necks, etc.
    This is not a new subject in the trike forum(s) and is something that should be avoided when selecting a tow bar. Look for one that has a horizontal hinge, or uses a regular ball receiver. Plus it would ideally attach to the trike frame at the back end to take all strain off the neck area.
    Sep 2011
    Understand!!
    150+ Posts Bob Witte's Avatar
    Jan 2010
    Hudson, FL (near Tampa)
    I wonder if anyone has done a hauler like I'm thinking about and/or why it wouldn't work (at least for local use). My idea is to have a dual armed "fork" that attaches to the front tubes. This would allow the trike to be pulled with all three wheels on the ground. It would swing side to side and up/down via a simple universal joint mechanism.
    What think ye?
    Bob Witte
    The Ghost of Trinity Trike Past
    Sep 2011
    Scroll down till you see the one for a trike.
    http://www.motorcycle-rack.com/MFWT.html
    Aug 2010
    Harvest, AL USA
    Bob Witte: I understand your concept - sounds like a viable solution for towing. I only recommend that you include some mechanism in your design to protect against the front end of the trike raising up in the case of a panic stop. I learned that little lesson the hard way when my trike come up and nearly kissed my SUV rear window in a quick stop. I look at using a simple ball hitch coupler to work as a universal joint for my towbar designs - simple and cheap.
  19. #19
    Sep 2011
    Has some good pictures!
    Trike meenemen
  20. #20
    Jan 2010
    Point well taken and just in time! I'm heading over to a shop today to see what it would take to build such a connection system. Wish me luck.
    Bob Witte
