SSpoon1SSpoonNew Member Introduct...Hello from VA
Results 1 to 16 of 16
Thread: Hannigan shock setting
    Tennessee
    Default Hannigan shock setting
    What setting do most have their shocks set? Sure would be good if the adjustment was at the bottom of the shock and not at the top where you have to remove the wheel in order to gain access.
    70+ Posts A WINGER's Avatar
    Feb 2012
    Chattanooga (Hixson), Tennessee
    Default Re: Hannigan shock setting
    We ride position 3 on rt and 2 on left to counter the road crown. AT 475 #s plus gear, we are very happy with the ride and handling.
    A
    Alan, AD4HE + Trish, KD4LGZ
    08 GoldWing - Hannigan
    41' Sailboat 42' RV
    1971 Triumph Trident
    1968 Triumph Bonniville 650
    1966 Triumph Trophy 650
    1948 Harley 125 & Whizzer
    1939 Indian Chief
    Tennessee
    Would also like to hear from some Harley owners concerning the shock setting. I never thought of setting one side different from the other, but guess it would work. I just fool with the tire pressure for compensating for the crown.
    Nov 2009
    Mass
    I don't understand the "crown" theory????? Are we assuming that we are always taking a right hand turn? The roads go both ways....I don't get it? BOb.
    Feb 2012
    The road is crowned in that it is higher in the center as compared to either the left or right side. The crown allows water to run off rather than sheet or puddle in the middle. The trike alignment needs to compensate for running along this banked surface.
    A
    41' Sailboat 42' RV
    1939 Indian Chief
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    I think most roads that have a "large" crown are in the south because of the heavy rains. In the north you would never feel the crown on the road. The only crown around here are roads which have heavy truck traffic and a crown forms from use, but most of the time these roads are skimmed to get the crown out.
    Regards,
    Rosy
    From NH
    Pawn In The Game Of Life Veritas44's Avatar
    Sep 2011
    Aequitas, KY
    Some espouse the theory of one notch higher on right than left-Some do not.<br />
    Actually a subjective preference as opposed to an objectively proven rule. Neither Right or Wrong-Good or Bad. Another &quot;To each their own&quot;.<br />
    Regardless of bike (GL, HD, Yammy, Kawi, BMW, etc.), set them at the middle pre-set for the majority of situations and owner/operators. Should Rider(s) be less or more &quot;gifted&quot;, it is acceptable to vary up or down one notch to the 2nd or 4th pre-sets. <br />
    NEVER-EVER utilize the 1st-bottom or 5th-top notches. Don't even think about it. <br />
    <br />
    The shocks are inverted to maximize their effects and efficiency given design and unique application. The specifics of which are quite lengthy and technical. That's a dissertation for another day. Just have to trust when said &quot;Because they NEED to be&quot;.
    250+ Posts Stephen's Avatar
    Jul 2010
    West of Houston
    I guess now I've heard it all on this subject... more air in this tire than the other tire, set this shock different then the other... nobody does this on cars. This isn't the Indy 500 and your name ain't (put famous race car drivers name here) and you ain't driving 200 MPH on a high speed race track. What do you do when you get on a freeway which isn't crowned, put over and have the pit crew make chassis and suspension adjustments before you get on the freeway? <img src="images/smilies/shrug.gif" border="0" alt="" title="Shrug" class="inlineimg" /><br />
    <br />
    Being a lightweight 190 pounds and beings as I travel light shocks are set all the way down for softest ride possible, 30 (to 40) PSI in the tires as recommended by the RS factory. If I need some extra stiffness in the shocks for those curvy roads I push the preload button and add that stiffness in. That's all there is to it.
    Jul 2010
    West of Houston
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>whizzer</strong>
    <a href="showthread.php?p=115242#post115242" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">What setting do most have their shocks set? Sure would be good if the adjustment was at the bottom of the shock and not at the top where you have to remove the wheel in order to gain access.</div>
    </div>
    </div>
    </div>Weight plays an important part in this, you can't ask someone who is 300 pounds, has a co-rider that weights 200 and carries 50 pounds of luggage around how to set up your unit when you weigh 150, no co rider and no other weight.
    80+ Posts
    May 2011
    Edinburg,Texas winter, Northeast Ohio summer
    Whizzer-
    I weigh 200#, my wife weighs 1xx#. We have traveled across the U.S. and Canada this summer loaded for travel with shocks at lowest setting without complaint.
    Feb 2012
    Quote Originally Posted by Deadeye View Post
    Whizzer-
    With 500#s of spare fuel, luggage and people the 2-3 combo works for us.
    A
    41' Sailboat 42' RV
    1939 Indian Chief
    80+ Posts Goldendragon's Avatar
    Feb 2013
    Bend, Oregon USA
    I'm usually fully loaded to the hilt on long trips and set the shocks on the highest (stiffest) setting.
    600+ Posts berngren's Avatar
    Jun 2011
    Saginaw, TX
    Since I'm the only rider - I set mine at the middle. No problem if I have a passenger - or pulling the trailer. Smooth ride either way.
    Jan 2012
    Dover, NH USA
    I think you should know how your trike work by the "feel". I had a problem "bottoming out", so I had my preload on the shocks stiffened. This works for me and my co-driver.
    Run it, adjust it and see if it is better, if not go back, or if it is, then leave it.
    Good luck, as I have said before, no two trikes are the same, weight, tires, reloads, and wear all play a factor.
    Regards,
    Rosy & Janice
    From NH
    May 2013
    LEESBURG, FLORIDA
    Quote Originally Posted by Veritas44 View Post
    Why do you say NEVER-NEVER? What happens at each end of the spectrum?
    30+ Posts ectrike's Avatar
    Feb 2011
    Howard KS
    Quote Originally Posted by Rosy View Post
    Regards,
    Rosy
    From NH
    Some states have crowns and have one side lower than other. No road is flat.most people don't know it. You can't leave water standing on the road.
  1. Preload Setting
    By MDGeorge in forum Honda Trikes
    Last Post: 05-20-2013, 05:40 PM
  2. Clock Setting
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 03-25-2013, 11:14 AM
  3. trike not setting level
    By arnie in forum Harley Trike Conversions
    Last Post: 04-10-2012, 08:27 PM
  4. OMG - Air shocks setting - HELP...
    By Big0 in forum Stallion Trikes
    Last Post: 05-09-2011, 02:56 PM
