Results 1 to 4 of 4
Thread: Bad bearing in Motor Trike rear end.
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    Default Bad bearing in Motor Trike rear end.
    I thought Motor Trike rear ends were maintance free. I just took the rear end apart on my wife's trike and the bearing that is next to the pully on the left side is shot. It is not a sealed bearing as is the one on the other side, surely it is susposed to be, there would be no way to grease or clean it without taking the whole thing apart. If it is not susposed to be a sealed bearing then every one of them will fail. I wonder if the seal got knocked off some how ?
    Anyone else have this problem ? I will call MT on Mon. and ask. I can't figure out how to get the pulley off, the whole thing came out in one piece from the housing the right axle is still in. Do they have a manuel for these things ?
    Thanks for the help,
    SR
    Sep 2009
    Near Myrtle Beach SC
    Default Re: Bad bearing in Motor Trike rear end.
    I can report that I have 45k miles and no seal issues on my Motortrike rear end.
    As far as manual for disassembling the rear end, several years ago I ask a dealer about that out of curiosity and he told me he would have to ship the rear to Motortrike for repair. I can tell you its either a 7.8 or 8.8 Ford rear end they buy used and modify for the trikes.
    200+ Posts
    Jul 2010
    Cotopaxi,Co. USA
    Thanks FLTR2008TRIKE. I had pretty much figured on doing that.
    Thanks again,
    SR
    150+ Posts bullet 10's Avatar
    Oct 2010
    climax springs,MO
    Motor Trike has a 3 yr unlimited mileage warrenty. How old is your kit? They are a great CO. to work with issues. Road one on a 99 RK for over 100,000 Miles before buying my present 2010 HD Tri.
    ttom, wife and triglide:clan:
  1. Motor Trike rear end noise!!!
    By iowatree in forum Motor Trike
    Last Post: 06-03-2015, 10:12 AM
  2. Motor Trike Rear end Question
    By Paul_Trike in forum Honda Trikes
    Last Post: 03-19-2012, 09:49 PM
  3. CSCdaytona trike jack shaft bearing problem
    By denray in forum California Sidecar Trikes
    Owners Forum
    Last Post: 10-24-2011, 08:02 AM
  4. v8 trike steering bearing
    By jasandbob 2 in forum General Discussion
    Last Post: 11-15-2010, 03:44 PM
