Results 1 to 9 of 9
Thread: CSC and 30 tooth transmission sprocket
    80+ Posts Countryal's Avatar
    Feb 2011
    Eclectic,Alabama USA
    Default CSC and 30 tooth transmission sprocket
    Just had my HD dealer change my 32 tooth to 30 tooth transmission sprocket. Wow what a difference! I wasn't sure the change would work on a CSC conversion but it does. If anyone is thinking of a CSC conversion change the sprocket at the same time you'll be glad you did. also try and get a little shorter belt as you loose almost all of your adjustment. After going to the Rally I knew I had to do something or I was going to loose my clutch.
    [SIGPIC][/SIGPIC]
    2000+ Posts Rick Kay's Avatar
    Dec 2011
    Huron, Ohio
    Default Re: CSC and 30 tooth transmission sprocket
    I've been wondering about that... Did you get the belt from CSC?
    Rick
    2006 FLHTI/2012 CSC Daytona
    1987 FLST
    Feb 2011
    Rick, They put my stock CSC belt back on, I had called CSC and they said it would work all the way up to a 4 tooth change. The mechanic said after the change I had approx 3/16 in. left of adjustment so it just barely worked(2 tooth change). If I had known this I would have looked for a shorter belt. I hope it don't stretch anymore although they said I could probably lengthen the adjustment slot a little if I had to. CSC needs to advise everyone that uses there conversion to change the sprocket or they need to change their gear ratio. I think it is geared too high.
    [SIGPIC][/SIGPIC]
    150+ Posts KRUZR's Avatar
    Oct 2010
    Aurora, IL, USA
    I have the 30 tooth pulley on my Trike and I seem to re-call that my conversion installer telling me that CSC provides a heavier drive belt and that there was plenty of adjust to compensate for the 30 tooth pulley. I also verified this with Tech Support at CSC. Ride Safe!
    Black Pearl 2007 Street Glide/2010 California Side Car Conversion
    Feb 2011
    Quote Originally Posted by KRUZR View Post
    Kruzr, I had my conversion done at CSC last year and after the conversion I called back to see If they offered a different sprocket because I felt it was geared too high and they said no. It looks like they would have told me about the belt and the Harley sprocket. My Harley dealer changed the sprocket and they called CSC about the belt adjustments and as far as I know they didn't tell them of the different belt. If I had known of the Sprocket and Belt at the time of the conversion I could have saved a lot of money by having the sprocket and belt installed at that time. Better yet It should have been designed to work without any other modifications.
    [SIGPIC][/SIGPIC]
    Oct 2010
    Aurora, IL, USA
    I actually had the 30 tooth before the conversion and called CSC Tech Support "Kyle" and he said it would OK to stay with the 30 tooth. Had my installer call also. If you have the 30 tooth installed now, I don't believe you will need a pulley change. CSC doesn't care which one you have, they have the kit set up to match the stock gear ration of a Harley. And everyone on the forum believes the 30 tooth is the way to go. I'm not a mechanic this information is to my best recollection. Ride Safe! If you would like I'll get you the name of my installer at Woodstock, HD here in Illinois.
    Feb 2014
    guthrie ok usa
    Quote Originally Posted by Countryal View Post
    What did it cost to have the 30 tooth sprocket installed??
    Banned
    Feb 2013
    Russia
    Quote Originally Posted by herbie56 View Post
    Just me... but I imagine it's a fair amount of labor. If I'm doing "labor", I'd rather be tuning a motor with the same money.
    Nov 2017
    Austin
    Default CSC 30 tooth sprocket....
    how is your harley d trike doing so far? I'm thinking about doing on my csc trike... the csc factory offer an option performance gears now... a 6 speed bikes are $460.00 These kits include a 30 tooth front sprocket and speedometer calibrator, on the 6 speed bikes it also includes a 43 tooth Jack Shaft sprocket that goes on the trike kit. I need to know isn't worth it and does it make easier to accelerate and increase the torque?
    let me know...
    thanks
    Joe
  1. Changing Triglide Transmission Sprocket
    By msocko3 in forum Harley Tri Glide
    Last Post: 06-24-2019, 06:47 AM
  2. Sprocket 32 tooth TRI GLIDE
    By Gorilla in forum Harley Tri Glide
    Last Post: 08-03-2018, 08:01 PM
  3. TG 32 tooth sprocket.
    By rick1201 in forum Harley Tri Glide
    Last Post: 12-26-2016, 01:20 PM
  4. blue tooth
    By rayg5102 in forum Accessories
    Last Post: 12-23-2016, 10:34 AM
  5. 30 tooth tranny sprocket for 2007 flhtc trike
    By captdanwh in forum Harley Trike Conversions
    Last Post: 07-18-2013, 12:37 AM
