Likes Likes:  1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 42
Thread: Car Tire on Front
  1. #21
    30+ Posts stargzr57's Avatar
    Nov 2010
    Green Bay Wi.
    Default anyone use a car tire in front
    I have a gl 1800 with a hannigan kit. Right now I have a bridgestone barracks bt45r mounted in reverse. I only have approximately 5000 miles on. And it sounds like I have a big 4x4 truck tire on! And at 30 MPH or less the handlebars vibrate. Before I triked my wing I went darkside and loved it it ran so quiet and got great mileage. Sooo anyone using a car tire on the front and if so which one size etc.and do you like it.
    Thanks to all, Steve
    2007 orange goldwing w/ 2010 hannigan trike kit:wave4:
    TOI wisconsin
  2. #22
    Nov 2010
    Green Bay Wi.
    Default Re: anyone use a car tire in front
    Sorry it's a battlax. Damn spell corrector lol
    TOI wisconsin
  3. #23
    May 2011
    San Angelo
    Quote Originally Posted by stargzr57 View Post
    Steve, it sounds like you have other then tire brand/type problems. Many of us are running the Battleaxx (forward and reverse) with nothing but praises. I'd be looking at steering head or wheel bearings. Maybe even the forks. Yes, I'm grasping at straws.
    Unless you got hold of a bad tire I really don't think the rubber is the issue.
    OH, to answer you original question. Unless you are willing to drop something like $4000 for the Euro front end which will accept a car tire the MPA and BT45 are your best bets.
    2015 GL1800/Roadsmith HTS1800
  4. #24
    250+ Posts Stephen's Avatar
    Jul 2010
    West of Houston
    Quote Originally Posted by Gold Rush View Post
    Steve, it sounds like you have other then tire brand/type problems. Many of us are running the Battleaxx (forward and reverse) with nothing but praises. I'd be looking at steering head or wheel bearings. Maybe even the forks. Yes, I'm grasping at straws. Unless you got hold of a bad tire I really don't think the rubber is the issue.
    Agree 100%!
    I did read about someone who put a car tire on the front... I think when it came off the lift and he found out how hard it was to steer he had them put it back on the rack and take it off.
  5. #25
    Nov 2010
    Green Bay Wi.
    I must have gotten a bad tire if you run your hand over it you can feel the highs and lows in the tire. I just had the bearings checked and new fork seals in, I have never seen a tire wear like this.
    TOI wisconsin
  6. #26
    May 2011
    San Angelo
    Sounds like you've done some trouble shooting in the right areas. Would be interesting to see what the Bridgestone Gurus would have to say. Might be worth calling them. Keep us posted please.
  7. #27
    Mar 2011
    mountain home,ar. USA
    I switched from the Michelin Pilot Activ the BT-45 and it's much quieter than the MPA which always had a whine and vibration from tread pattern. I am also run Centramatics on the front, a Traxxion fork brace, and have had the Traxxion AK20 cartridges and springs installed.
    As others say, I think you've got maybe fork problems, bad tire, etc. You didn't say how many miles are on the trike so it may be time to have the front end completely gone through. Also, I believe the consensus is that 41 psi is required in the front tire to perform correctly.
  8. #28
    Nov 2010
    Green Bay Wi.
    Quote Originally Posted by mhgoldwing View Post
    The trike kit was installed only two years ago,so I am leaning toward a bad tire.I got the tire from wingstuff and was only $99.00 maybe this is why it was so cheap ? Maybe they had a bunch of old tires to get rid of?
    TOI wisconsin
  9. #29
    Nov 2010
    Green Bay Wi.
    Ahhhh I wonder it this was caused by a bad fork seal I had I didn't notice it right away so it was probably bad for a few thousand miles. Thank goodness it was covered under warranty! Maybe I will try another battlax and to be safe maybe from a different supply.
    Anyone have any thoughts on this please chime in. Is this a great site or what!
    Thanks to all for the info ,Steve
    TOI wisconsin
  10. #30
    First_N_Last
    Guest
    Default Re: Car Tire on Front
    For my RSV with a Voyager Kit on it, I used a Avon Venom rear (reversed) on the front. 17,000 miles on it & I'm happy with it. Lowered the pressure to flatten it a bit.
    Only problem is the sidewall cracking...
    JohnB
  11. #31
    500+ Posts wiredgeorge's Avatar
    Sep 2012
    Mico, TX.
    Default car tire up front?
    If you ride a trike without using the sidewall of the tires in back, why not use a car tire up front? The only thing I can think of is inability to find the correct size...
    wiredgeorge Mico, TX.
  12. #32
    1750+ Posts Trent's Avatar
    Jul 2011
    Meridian, ID. USA
    Default Re: car tire up front?
    You hit the nail on the head. Dunno about a Wing, but I tried to find a tire that would fit my TG thru several different tire dealers. Just wanted to give it a try. Not a single thing available that would work. All too wide. Just my experience though.
  13. #33
    Sep 2012
    Mico, TX.
    I looked a bit an there are car tires in 18" BUT the aspect ratio was 40 or 45 which would make them way too wide. I found one car tire in the correct size (I think). It is for antique cars and I am not sure if it would work well at modern speeds/roads:
    Excelsior All Black - 450-18
    You can also find this tire in a 475/500 width (18"):
    Excelsior Tires - Buy Antique and Vintage Tires Online from Performance Plus Wheel and Tire
  14. #34
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    I do not understand the sizing. 450 is the tire width in inches (1/2" ) don't sound right. If metric it is too wide. My rear are 225 and they are huge. If the 450 is wall height that can't be either. HELP,!!
    I just looked back at the 1st link and looks like 450 is really 4.5 " (4 1/2")
    Figuring out max clearance is the trick..
  15. #35
    Sep 2012
    Mico, TX.
    Both motorcycle tires and car tires were measured in inches prior to the current metric system. 450 tires are 4.5 inches wide, fit on 3" rims that are 18" tall. I am guessing this is the approximate size needed for a GL1500. In the early 70s, ALL motorcycle tires were listed in inches.... a standard front tire for a Z1 was 325-19. They obviously had more narrow rims than a GL1500.
  16. #36
    50+ Posts shadow's Avatar
    Jun 2009
    Ahwatukee, Arizona
    Avon is suppose to be looking into a car tire for the front of trikes. Has anyone heard anything on that ???
    [SIGPIC][/SIGPIC]
    Ron & Nancy Pierce
    TOI ~ Arizona
    Missing In America Project
    www.miap.us
    Patriot Guard Rider ~ Arizona
    www.azpgr.org
  17. #37
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Trent View Post
    For the TriGlide front I use a 130/90/16 Dunlop 501 GT rear tire mounted in reverse on all my customer's TriGlides and Harley FLH-FLT trikes.
    Jim Murphy
    Iron Butt Rider 2001
  18. #38
    1250+ Posts bustedwing's Avatar
    Mar 2012
    Hermansville, Mich. USA
    I know this is an old thread and I would like to see if anything has changed. I have a Gold Wing 1500 trike and just wore out the front tire, a Michelin Pilot. The center 3 inches of the tire has all the wear, but the rest of the tire looks like new. Even the casting nubs are still very prominent. I know this subject has been hashed before, but why should I pay a huge price for a tire that I can only use one third of the rubber? If I can find a car tire that has more of a flat tread so I can use more rubber without wasting it I believe it would work better. Any ideas? Thanx, Bud.
  19. #39
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    car tires have been used on the front of motorcycle/sidecar rigs in Europe for years. Here is a company in England that will make you a whole new front end ready for a car tire and the hub to mount it on. I am saving my money. I actually found out about them here from a post by a member from England
    Wasp info@waspmotorcycles.com
    Happy TRAils/NSD
    Paul
  20. #40
    300+ Posts Cougar's Avatar
    Mar 2009
    Near-Iowa City,Iowa
    Thanks Paul, just sent them email for more info.
    Did you ever find out the cost ?
    Jeff
  1. Front Tire
    By RRSCOTT in forum Honda Trikes
    Last Post: 06-22-2013, 12:17 PM
  2. Car Tire on the front?
    By Strat in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2011, 09:06 AM
  3. Front tire
    By Smoken'JOE in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-03-2011, 07:30 PM
  4. Front Tire
    By subeetrikerdon in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-16-2010, 11:22 PM
  5. Front Tire
    By Ron58 in forum Harley Trike Conversions
    Last Post: 07-26-2009, 10:10 PM
