Results 1 to 6 of 6
Thread: quick question about converting to alternator
    80+ Posts classicfins's Avatar
    Feb 2011
    Ruston, La USA
    Default quick question about converting to alternator
    I just ordered a new chrome 55 volt EMPI alternator kit for my trike. I've never pulled a generator before so I've got a question. Is this install going to be easier and quicker in the long run just to pull the motor cage and drop the entire engine? I'm old and fat and the body covers the entire engine so I'm looking for the easiest overall route.
    Doug Young
    Ruston, La
    Proud VW Trike Owner
    '86 Stallion built by Arizona Trikes
    Some people are like slinkies...
    Not much good for anything, but they sure are fun to push down the stairs...
    20+ Posts rbourne3's Avatar
    Jul 2010
    Fernandina Beach, FL
    Default Re: quick question about converting to alternator
    It is all but impossible to remove without removing the shroud. The fan in the shroud is about 10" and comes out with the gen/alt. I would think lifting the body would be easier, but that is your call. To try to get it off without removing the shroud, you can unbolt the carb, manifolds, and generator stand, and remove the gen stand and all. You still have to loosen the shroud, but it is possible.
    Feb 2011
    Ruston, La USA
    That's what I thought. Thanks!
    Doug Young
    Ruston, La
    Feb 2011
    Ruston, La USA
    We'll it's done. It wasn't as bad as I thought it was going to be. I removed the luggage box from the rear of the body and cut an acess hole and it went pretty quick. I installed an EMPI 55 amp alternator. It has a slight whine to it when you rev it a bit. Not much, just a touch. Is that normal?
    Doug Young
    Ruston, La
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    So you cut a hole in the body??
    Feb 2011
    Ruston, La USA
    Quote Originally Posted by Rsw View Post
    Yes, under the luggage box. I had seen a few done this way and I can see why they did it. It's dang near impossible to get to anything on top of the engine otherwise.
    Doug
    Doug Young
    Ruston, La
  1. Alternator whine
    By Konrad in forum Honda Trikes
    Last Post: 11-04-2013, 08:21 PM
  2. Anyone have an alternator whine?
    By kb9osl in forum Honda Trikes
    Last Post: 10-30-2013, 09:05 PM
  3. Rebuilding Alternator
    By jackpoet in forum Honda Trikes
    Last Post: 03-31-2013, 06:33 PM
  4. Alternator Problem
    By holdthepickle66 in forum VW Powered Trikes
    Last Post: 07-25-2011, 10:31 AM
  5. Question about Converting 2007 Fatboy
    By DonnaBoyd in forum Harley Trike Conversions
    Last Post: 01-25-2011, 08:52 PM
