Results 1 to 17 of 17
Thread: 2009 Reverse not working
    30+ Posts
    Jul 2010
    Hardin Ill
    Default 2009 Reverse not working
    I have a 2009 triglide that has a reverse that has stopped working, after shifting into neutral I push the reverse button and the light comes on, but nothing happens when push the down arrow. Any ideas? Thks, Chuck
    Oct 2010
    USA
    Default Re: 2009 Reverse not working
    Quote Originally Posted by tri glider View Post
    Did you check the circuit breaker under the I think the right side cover?
    There is a reset button to press if it was tripped. Like a circuit breaker.
    30+ Posts
    Jul 2010
    Hardin Ill
    Thks trikermutha, I just looked under the right side and didn't see anything that looked like a breaker. I then looked behind the left side and found a fuse box, but it didn't list anything indecating reverse. Thks.
    200+ Posts Boom's Avatar
    Mar 2010
    Sarasota, FL USA
    I think the '09s had the breaker under the seat. Maybe oldmsocko will jump in since he has an '09 also.
    2010 RHS Tri-Glide Ultra, Fuelmoto stainless headpipe, Supertrapp SE slip-ons, SE255 cams w/S&S lifters and TTS2 tuned by Docs Performance, Lenale parade fan, UltraCool Reefer oil cooler, ClutchWiz, Barnett+1 clutch pack. Hayden chain tensioner, crotch-cooler shields, Wild1 WO575 chubbies, Road Zeppelin air seat, 30t. primary belt pulley, Lyndall rear ceramic/aluminum rotors w/L. pads rear and front, Garmin Road Tech 660 w/radio interface, 1.25" lift brackets
    Oct 2010
    USA
    You know I think you are correct!!! I looks like a square device with wires on both sides on it and has a arm with a push button reset on it..
    It looks something like my picture..but not the actual part..just a example
    20+ Posts
    Apr 2012
    Front Royal, Virgina,USA
    2009 is under the seat. One of the dumbest places to put it! HD thought so too that's why it got moved on newer models to the right side.
    30+ Posts
    Jul 2010
    Hardin Ill
    Thks guys, now do you have to remove the tour pack to take off the seat?
    30+ Posts
    Jul 2010
    Hardin Ill
    Guys, I checked under my seat, but didn't find anything that looked like a breaker. Any more ideas? Thks
    Contributing Member SEAlaskan's Avatar
    Nov 2009
    Juneau, Alaska
    Look under the cross plate that the passenger hand hold is mounted to, you'll also see the reverse motor under there.
    Butch
  11. #10
    1500+ Posts
    Sep 2009
    North East Ohio
    Quote Originally Posted by SEAlaskan View Post
    Butch
    That is exactly where it is located, right under the seat to the rear
  12. #11
    30+ Posts
    Jul 2010
    Hardin Ill
    Thks Butch, I think I found it. It is a little red button behind the pass. handles. I push it down and I could it clicking when I pushed the down arrow, but it still wouldn't back up. I guess the motor is shot, it's been moving slower the last few times I had it out. Thks, Chuck
  13. #12
    Nov 2009
    Juneau, Alaska
    OK!! Did you noticed the red flag popping out when you pushed the red button? Did you push that flag back in (that resets the circuit breaker) it should be in the tucked position. The picture that Trikermutha has shows the red flag just below the red button in the proper position.
    Butch
  14. #13
    30+ Posts
    Jul 2010
    Hardin Ill
    I did find the breaker with a red button on the top. It has a little black arm that was angled off to the side that has reset written on the top and I pushed it back in, but still no reverse. Thks
  15. #14
    750+ Posts
    May 2011
    peru,in,usa
    do you have ext. warrenty?
  16. #15
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    I have an 09 and had a problem with no reverse. Reverse would reset, but wouldn't back up. You would still get the reverse light, but no go. Wasn't the motor it was the breaker itself. Replaced breaker and yes it is under the seat towards the rear of the trike.
    Had this problem when I first got the trike. Been through Hardin ridin the river road. Not far from you on the east side of the state on Rt. 50 140 miles from St.Louis , 9 miles from Vincenness, In.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
  17. DKCustoms postbit
  18. #16
    30+ Posts
    Jul 2010
    Hardin Ill
    Yes, I have about 11 months of warrenty left, and Rod if came through Hardin it didn't long. LOL Thks Guys, Chuck
  19. #17
    40+ Posts
    Jun 2011
    tyler mn.
    there were many bad reverse components in 2009.motors ,switches,etc.they were poorly built.good luck the repairs could be expensive. the 2009 had lots of issues,radios,starters, brake components,starters,switches,
  1. Reverse not working
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 09-04-2018, 04:15 PM
  2. A/C not working?????
    By Backdraft in forum Stallion Trikes
    Last Post: 09-27-2013, 07:30 PM
  3. Clock not working
    By rickt in forum Honda Trikes
    Last Post: 08-28-2013, 10:44 AM
  4. Not all of us were working today......
    By werewolf in forum General Discussion
    Last Post: 05-21-2013, 09:51 PM
  5. Calendar is working
    By Lucky in forum General Discussion
    Last Post: 01-06-2013, 02:15 AM
