Results 1 to 6 of 6
Thread: Roadsmith Question
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Question Roadsmith Question
    I have a new Roadsmith conversion on my 05 Wing. I'd like to take the tires off to dress up the tail light wires. One side at a time if I have to.
    What is the best way to lift the rear end off the floor? Placing the floor jack directly under the differential, or on the frame backing plate directly in back of the differential?
  2. Roadsmith banner
  3. #2
    Mar 2011
    mountain home,ar. USA
    Default Re: Roadsmith Question
    The lift point is the metal bracket at the bottom of each rear shock. If you lift in the center the trike will not be stable as it can rock to either side and fall off jack. I only do one wheel at a time for safety.
  4. #3
    Feb 2009
    Palmyra, Virginia
    Thumbs up Re: Roadsmith Question
    Quote Originally Posted by mhgoldwing View Post
    Thanks MH. Will do.
  5. #4
    900+ Posts jtilmon's Avatar
    May 2011
    Collierville, TN USA
    Rich, I ride a Roadsmith and jack it with a motorcycle jack under the frame backing plate the diffential attaches to - the jack is as wide as the plate and everything balances very well. Use small jack stands under frame forward of the wheels for safety. Then you can remove both rear tires at the same time. I have 215-45-17 tires on rear and cannot get them from under the fender of the trike unless I jack in the center and let the wheels drop down.
    jtilmon
    GL 1800 / Roadsmith / Caliente Red
  6. #5
    Feb 2009
    Palmyra, Virginia
    Quote Originally Posted by jtilmon View Post
    Using a motorcycle jack under the backing plate makes alot of sense regarding the balancing issue along with the fact that the wheels would then drop down making removal much easier. Looks like I shouldn't have sold my motorcycle jack a few years ago when I sold my Intruder. Guess I'll just pick up another one. Thanks for the tip!
    Mar 2011
    which motorcycle jack do you have? Sounds like the best way to get the job done.
  1. Roadsmith Trike question
    By coolpoolken in forum California Sidecar Trikes
    Owners Forum
    Last Post: 08-20-2017, 06:22 PM
  2. GL1500 roadsmith question
    By brianl in forum Honda Trikes
    Last Post: 06-17-2013, 02:09 PM
  3. Roadsmith question
    By steve047 in forum Honda Trikes
    Last Post: 11-29-2012, 07:12 AM
  4. Question for RoadSmith owners
    By Konrad in forum Honda Trikes
    Last Post: 02-25-2012, 02:59 PM
  5. silly roadsmith question
    By rodeo1 in forum Honda Trikes
    Last Post: 07-05-2011, 08:54 AM
