ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Results 1 to 9 of 9
Thread: Roadsmith Gas Leak
    oldwing1
    Guest
    Default Roadsmith Gas Leak
    Hi Everyone,
    I have a 98 GL1500 SE with a new Roadsmith Kit. I have a problem that developed when I put my first tank of gas in it. It is leaking gas on the left side after I come to a stop and there is a small puddle on the ground. I thought I had overfilled the tank so next time I made sure I did not. Same thing. After a while of riding on that tank the leak stops unless I make a hard right turn and it starts leaking again. My dealer removed the wheel and retightened the connectors for the gas line but that did not fix the problem. I live on an island and don't have much of an oppertunity to ride a few hundred miles to take it to a Roadsmith dealer. I tried to get a look under it but it is too low to the ground to see much.
    I did notice that the filler cap tube has 2 nipples on it at the fill end. One of them has a hose connected and going somewhere but the other is just open. I wonder if that is where the leak is coming from and if I should try and block it off.
    I was wondering if anyone else has this type of tank and there is an open nipple at the top as well. Thanks for any info.
  2. Roadsmith banner
  3. #2
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Exclamation Re: Roadsmith Gas Leak
    I don't have a 1500 but what you're describing doesn't sound like it's an issue with the Roadsmith conversion, unless you have the optional auxiliary gas tank Roadsmith offers as an option. If not, it seems like you have a problem with the bike's gas tank itself. Could it be possible that it was some how damaged when they installed the Roadsmith conversion? When you fill the tank, are you able to see any wet areas on the tank (remove seats, panels) to at least localize where the leak is coming from? Just suggestions. Hope you find it!
  4. #3
    oldwing1
    Guest
    Default Re: Roadsmith Gas Leak
    Thanks Rich, Sorry about that, I forgot to say that I do have the extra gas tank conversion and the above description is on the Roadsmith. Sorry for the confusion
    Charlie
  5. #4
    80+ Posts trucker's Avatar
    Jul 2011
    Pennsylvania
    call roadsmith up and see what they have to say about it.
    2009 Honda Goldwing/Roadsmith Trike. Color - Candy Black Cherry (Triked 10-22-11). ThumbUp
    2007 Suzuki Burgman 650. Color - Phantom Grey
  6. #5
    someone else had a problem with a leak on a auix. tank on a new conversion. can not remember what conversion though.
    oldwing1
    Guest
    Thanks Guys, I'll wait till they open next week and give them a call.
    500+ Posts Konrad's Avatar
    Nov 2010
    La Grange, KY
    I have the Roadsmith conversion with the aux. tank. On two occasions I filled the aux. tank just after transferring all fuel to the main tank. Problem: I forgot to TURN OFF the pump switch the first time and accidentally hit it with my knee the second time. Result: Bike quit after a tenth of a mile and was leaking gas on the ground from the main tank. After switching off the leakage stopped and I was able to continue on my way.
    I'm wondering if that might be your problem?
    oldwing1
    Guest
    I'm pretty sure the problem is in the aux tank. It seems to happen if I am on the main tank or the aux tank. With mine the gas does not get transfered into the main tank. It closes the main and draws from the aux when the switch is in the aux position. I too have experienced getting about 50 feet and the thing shuts off and sure enough, I hit the switch and put it in the center no gas position.
  10. Roadsmith banner
  11. #9
    150+ Posts MarciaG's Avatar
    Cincinnati, OH, USA
    My trike with CSC kit had a gas leak. But it sounds like you have a different configuration on your Roadsmith so I'm not sure that what happened to me would apply in your case. But I would definitely contact Roadsmith. I'd also take it to a Honda dealer for a look-see.
    Good luck!!
    MarciaG
  1. Coolant leak
    By mrzip in forum Honda Trikes
    Last Post: 03-21-2013, 11:37 AM
  2. oil leak
    By Tinkertoy in forum VW Powered Trikes
    Last Post: 02-04-2013, 09:27 PM
  3. Leak ???
    By wobray in forum Harley Trike Conversions
    Last Post: 11-17-2012, 10:47 AM
  4. Another oil leak!
    By rwhgme in forum Harley Tri Glide
    Last Post: 03-28-2012, 08:21 PM
  5. Oil Leak
    By Roundabout in forum Harley Trike Conversions
    Last Post: 07-21-2011, 10:48 AM
