Likes Likes:  2
Results 1 to 20 of 29
Thread: VW air cool engine
    300+ Posts
    Apr 2010
    Sterling, Colorado USA
    Default VW air cool engine
    Hi All
    Just curios as to those that own VW tirkes that have the air cool engine what is the longest trip ( miles ) you taken/ driven in a day and what was your avg MPG?
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Default Re: VW air cool engine
    Longest trip was to calif, and average 600-700 miles per day and have gotten 42 MPG, with a single port motor with autostick[ stock motor] and traveling at a speed of 65-70 MPH. with a freeway flyer gear in 4th.
    300+ Posts
    Apr 2010
    Thanks vwmaniac!
    Sent u a PM
    90+ Posts
    Mar 2012
    Osage Beach, MO. USA
    Not the longest trip, but about 250 miles. My gas mileage was terrible, about 24 miles to the gallon. However I was running 80 miles an hour and with the large VW engine the Trike Shop put in their Roadhawk and auto transmission.
    2 bb
    5+ Posts skeeter's Avatar
    Jun 2012
    knoxville , tn , usa
    i was a vw air cooled tech in thier heyday 60/70s . had the first vw trike in knoxville tn. 1972 . don't get me wrong , but the air deal , well it was good at the time. my trike now would be very lucky to get 30 mpg. 1970 b case with dual port heads . cammed about 3/4. about 60 + horse . less than a 1000 lbs . but still , don't look for mpg air cooled .not gonna happen . don't get me wrong . this is my 14th air cooled vw . i love them like i love a dog . you can't just keep them around like a cat . you have to pet a vw about every day . but the good thing is you can.
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Did Sturgis this year, from central MO. Longest leg was 650 miles on the return trip. MPG dipped as low as 24 at avg speeds of 75 in a typical SD head wind of 40-50 mph. Best avg mpg was 30. 1600 DP with a mild cam behind a stock IRS tranny.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I have ridden mine all day in the heat. About 280 miles, didnt go anywhere, just in the wind. I have no cooling tins or fan at all and a 2110 stroker motor. No problems with overheating. More worried about the old point ignition letting me down.
    300+ Posts
    Apr 2010
    I have ridden mine all day in the heat. About 280 miles, didn't go anywhere, just in the wind. I have no cooling tins or fan at all and a 2110 stroker motor. No problems with overheating.[B] More worried about the old point ignition letting me down[/B].
    Thanks everyone for the info.
    DeathBySnuSnu- I am looking at changing over to electronic ignition.
    I got 22-25 MPG while driving from St. Joseph, Mo to Sterling, Co. It ran rough from one elevation to the other:
    St Joseph- Elevation: 885 feet to
    Sterling, Co- Elevation, 3,935 ft
    I have not tried to go on a extended trip because the first time after getting back my fuel pump went out and a week or two after that points broke leaving me on the interstate. So hopefully going to get a few things fix before going on a trip over 100 miles.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    When i first got mine on the road a couple years ago i had wierd ignition problems. I had one of the conversion modules. But it died quick. I dont know if it was at fault or not. I went through several condensers and bosch blue coils. I was broke down again one day and bought a cheep mr gasket coil. Guess what.....not a single ignition problem in over two years now. But i do want to go electronic. Most likely crank trigger distributerless.
    I dont get very good mpg.
    Run an electric pump with a regulator.
    300+ Posts
    Apr 2010
    Thanks- The fuel pump it has is electric. We did and a fuel regulator and it ran way better then it did.
    Apr 2013
    Canton, Tx, USA
    Anybody have experience with crank triggers? I have 71 1600 w/ duel Webers. Looking to get rid of the points and want the most dependable.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    A mega jolt, ford crank wheel and position sensor. Ford edis coil pack.
    Of course the mega jolt is a variant of the mega squirt. So if you are going to go that level of setup programming then might as well go fuel injection too.
    It is not all that difficult to do. The parts for the most part are cheap. Most of the components are standard v-8 car type stuff (not race stuff). The weber look alike throttle bodies are pricey, but if you are not concerned with what they look like then there are plenty of throttle bodies in the junk yard. The programming software is free to download.
    60+ Posts
    Nov 2012
    fontana, ca.
    compu fire has one
    Volkswagen
    60+ Posts
    Nov 2012
    fontana, ca.
    doghouse repair has the drop in module for the 009 distributor.
    https://www.doghouserepair.com/store...dv-drop-in-cf/
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I could sorta like the first one, hot coils are good. But this is not a crank trigger and you are still stuck with the advance curve of the distributer.
    20+ Posts
    Mar 2008
    Inland Empire, So calif
    Did over 400 miles the first day of a three day ride, over all got about 24 mph. with a balky carb., . A lot of up hill driving that first day.
    450+ Posts werewolf's Avatar
    Jan 2013
    Central part of God' country ie Kansas
    Depends a lot on the WIND in Gods country.
    If it is a calm day I get about 30mph.
    If the wind is blowing, ie 20 mph, mpg goes DOWN.
    Since I only have a five gallon tank, and most towns
    are about 30 miles apart out here, I usually fuel every
    60 to 90 miles.
    300+ Posts
    Apr 2010
    Hi all
    Stopping by to say hello...I must say I do miss the trike.... who knows maybe next year...
  19. #19
    May 2012
    Vienna, MO USA
    Good to hear from you, Joey! Stay in touch!
  20. #20
    300+ Posts
    Apr 2010
    Hi Guys just checking in.... I really miss having a trike....maybe in a year a two I might get one.. ( sooner if I hit the lotto)... hope everyone is doing well
    Joe
  1. Very Cool.
    By Smoken'JOE in forum General Discussion
    Last Post: 02-06-2012, 05:40 PM
  2. I am so cool
    By Stephen in forum General Discussion
    Last Post: 09-24-2011, 07:08 AM
  3. OK... this is cool
    By Mr.Wizard in forum General Discussion
    Last Post: 01-16-2011, 03:06 PM
  4. Just because it's cool!
    By mkparker in forum Home Built Trikes
    Last Post: 01-02-2009, 10:30 AM
