Likes Likes:  1
Results 1 to 9 of 9
Thread: Master cylinder for rear brake
    May 2012
    Lowcountry, USA
    Default Master cylinder for rear brake
    Almost done with a 2003 Ultra Classic conversion. I used a DNA rear which has their 4 piston calipers. I can't get a good pedal. I have bled and bled, no air in system. I don't think the stock master cylinder has enough volume. Has anyone run into this problem? Any suggestions on a replacement master cylinder?
    250+ Posts cscsonny's Avatar
    Dec 2011
    St.Louis,Mo.
    Default Re: Master cylinder for rear brake
    Have you bled it at the master cylinder ? Could still have air on that end.
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    What size is it?
    the Performance Machine replacement master cylinder for trikes is 3/4 it works.
    May 2012
    Lowcountry, USA
    Cscsonny, yes I have bled master and caliper quite a few times.
    Rsw, it's stock Harley master. Don't know the bore size, have heard they are 11/16.
    The problem is, the first time you push pedal, it goes all way to bottom and then second push, you have a fair pedal (not great) about half.
    Thanks Gorrilla
    Aug 2017
    englewood fl
    Default brake lines
    Quote Originally Posted by jimmib View Post
    hope you got the master figured out I just purchased a kit still in route The kit doesnot come with rear brake lines .What did you use thanks
    Apr 2019
    Clovis, CA, USA
    Quote Originally Posted by scooterfxr View Post
    I used the brake lines for a triglide. I have an 03 road king.
    Quote Originally Posted by AmericanMan View Post
    Chad............Welcome to Trike-Talk.................
    Jul 2020
    OCALA,Fl,USA
    No luck finding that. Anybody have a source?
  1. Need help with Brakes,master cylinder
    By BIBS in forum General Discussion
    Last Post: 06-16-2023, 07:37 AM
  2. Trike rear master cylinder problem ??
    By Pre-1898 in forum Home Built Trikes
    Last Post: 10-05-2018, 11:00 PM
  3. Rear Brake Master?
    By LadyKitty in forum Tires, Wheels, Brakes, Front End
    Last Post: 11-19-2011, 09:26 PM
  4. Master Cylinder Touring
    By Gorilla in forum Harley Trike Conversions
    Last Post: 06-30-2011, 11:33 AM
