gfaltersack3Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Likes Likes:  6
Thanks Thanks:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
Thread: Tri Glide Primary Oil
  1. #21
    Jan 2022
    Glen Saint Mary
    Default Oil consumption
    Might have to hold some cheese cloth behind the pipes next time I have it warmed up after a ride.
  2. #22
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Easy to get Formula plus. … On my 07 flhtc I have a Barnett at the time they said Redline was the best so that is what I’ve used. 10000 miles is what I try to get bet if not then once a year.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
  3. #23
    Jan 2022
    Glen Saint Mary
    Re-looked at exhaust pipe, and there is oil residue. Oil is getting through the pistons. Where it sat so long, would Luca's oil help any?
  4. #24
    Quote Originally Posted by DaveC32040 View Post
    Don’t know about Lucas… but back in the 60s when I used to monkey with engines i used Rislone oil treatment…👍
  5. #25
    Jan 2022
    Glen Saint Mary
    Thumbs up Oil consumption
    Thank you rhino 2.
  7. #26
    You should have a leak down test done to see if your rings are holding a seal and engine has good compression before trying anything else
    Oils are probably not going to help if you have poor ring seal and or valve seals leaking
  8. #27
    Jack.. Me’ I always use the law of parsimony (Occam’s Razor)..IE go to the easy solution first sometimes when an engine sits for long times’ Years? The rings can gum up .. If the Rislone doesn’t work then all the OP is out a quart of oil …
  9. #28
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Whatever primary juice you decide to use make sure you change it every oil change every time. Heres why- see that silvery fine particle sludge ( not chunks or slivers!)on the magnetic drain plug? Guess where else there are magnets? On the rotor. Those fine particles will attach themselves and over time will lead to your alternator shorting/ burning out.Its a fresh quart of oil now or a new alternator later. Might as well throw a new regulator/rectifer and battery onto the final bill- bad news comes in 3's. CHANGE THAT PRIMARY OIL!
  10. #29
    Keep in mind, many Twin Cam engines had poor machining of the cylinders when put together @ the factory
    This caused higher than normal oil usage, this is why a leak down test is in order here
  11. #30
    Jan 2022
    Glen Saint Mary
    To both rhino2 and Jack Klarich, thank you. Due to finances, I might try the oil additive first. If that doesn't work I might try and find you Jack. It looks like you're in Jax, Fl and I'm about 60 miles in Glen St Mary....lol
  12. #31
    You can reach me @ 904-304-3545, if I do not answer leave a message
    I am kind of familiar with where you live and will help you whenever I can
  13. #32
    Jan 2022
    Glen Saint Mary
    Thank you Jack. Your number is written down. By any chance are you doing the Boots on the Ground run on May 7th?
  14. #33
    I do not know what that is?
  15. #34
    May 7 th it’s a polka run in Jacksonville.. out of the flamingo Lakes RV resort..
  16. #35
    Jan 2022
    Glen Saint Mary
    Rhino 2 is right. It's a huge poker run, at least 600 bikes that run 13 different routes through Jax. It's to build money for vets, first responders and so much more.
  17. DKCustoms postbit
  18. #36
    50+ Posts Bouncer's Avatar
    May 2021
    Milwaukee, Wi, USA
    Quote Originally Posted by onahog View Post
    Just throwin this out there people..Lets Discuss!!
    What Oil do You use in your Tri Glide Primary?
    Why?
    How Much?
    How often R & R?
    ATF? Dennis?
    Please Explain, as we all value your choice!
    With the redesigned compensator I don't use ATF anymore.
    These compensators need a high quality oil because of the slide ramps and flat roller bearing.
    I've actually been adding a small amount of ZDDP additive to my primary oil because of the slide ramps. They work just like a flat tappet cam in older car engines. Hasn't effected the clutch function (no slipping) for the last 2 years and my primary is still clunk free.
  19. #37
    40+ Posts
    Sep 2015
    Cary, NC USA
    Thumbs up Amsoil - Nothing Better
    AGREED.
    Amsoil Engine and Primary. Transmission use Harley ATF - HOG wrench recommended (happy with tranny shifting).
    Three hole change every 5000-7500mi or at 1 year. Takes about one hour. Good insurance.
    I use Amsoil in the motor and trans, but like Formula+ for the primary.
    I don't use anything automotive in my Harley.....oils, tires etc. .....not counting wax's cleaner's etc.
  1. Primary Fluid Capacity
    By ttanthony in forum Harley Trike Conversions
    Last Post: 07-03-2013, 05:20 PM
  2. primary chain adjustment
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 03:03 PM
  3. Transmission/Primary Chaincase oil
    By Lakeman in forum Harley Trike Conversions
    Last Post: 06-21-2012, 07:49 PM
  4. primary oil change
    By whizzer in forum Harley Trike Conversions
    Last Post: 05-14-2012, 05:40 PM
  5. Primary Gear oil
    By tri glider in forum Harley Trike Conversions
    Last Post: 10-01-2011, 09:58 PM
