Results 1 to 6 of 6
Thread: lug nut on rear wheels
    TOI - Pennsylvania
    May 2008
    erie pa erie county
    Default lug nut on rear wheels
    being a new triker i was wondering if you should check the torque on the lugs nuts on the trike once a year or maybe sooner. my trike is new and i have only 800 miles on it. i will be going on a 1000 mile trip in june.
    750+ Posts
    May 2009
    Down South
    Default Re: lug nut on rear wheels
    If I had a new ride, the first thing I would do is a general nut-n-bolt check routine any place I could get to one on the machine. If you have never checked those lug nuts before, now is a good time. Never know how it left the factory. The spec. on mine is 85 pounds. With disc brakes, make sure you follow a sequence or you could warp the rotors....criss-cross just like on a car.
    Tour Master Trikerjim's Avatar
    Feb 2008
    Jemison,Alabama
    John, I check mine about every 3 or 4 trips I make on it. If you have aluminum wheels, I would check them more often. I learned back in my drag racing days that aftermarket wheels and "acorn" style lug nuts tend to loosen up sometimes. It doesn't take but a few minutes to check and makes you feel a lot better! Ride safe.
    "Making it home on our Wing and a Prayer"
    Jemison, Alabama
    GWRRA chapter: AL-Z
    '06 GL-1800 Motor-Trike 2+2 & '09 Aluma MCT
    [SIGPIC][/SIGPIC]
    400+ Posts
    Feb 2008
    Central Texas
    Lug nuts/bolts on a m/c trike should be treated the same as on an automobile or light truck. Use a torque wrench when mounting and recheck torque after 200 to 250 miles if the wheels are aluminum alloy construction. Do not (ever) use anti-seize paste on lug nuts or bolts.
    10+ Posts Paul06Trike's Avatar
    Apr 2008
    New Bedford, MA, USA
    What is the proper torque setting for the rear wheel lug nuts? I have a 2006 GL1800 Lehman Monarch II conversion. Thanks in advance.
    400+ Posts
    Feb 2008
    Central Texas
    Quote Originally Posted by Paul06Trike View Post
    Since no one else has posted a response, I will throw in my 2 cents. First, check the owners manual for the trike or ask the company that built the kit. Generally speaking I would think that from 75# to 80# should be sufficient. Do not use anti-seize paste on the threads. Torque the wheel nuts any time the wheels are removed and again after 200 to 250 miles.
  1. TriGlide Rear Wheels Specs
    By myxcape in forum Harley Tri Glide
    Last Post: 02-22-2015, 08:44 AM
  2. Rear wheels
    By GARYD in forum Harley Trike Conversions
    Last Post: 02-28-2013, 04:40 PM
  3. Rear Wheels - Re Chrome, Paint or new ??
    By Two Showers in forum Tires, Wheels, Brakes, Front End
    Last Post: 03-24-2011, 05:05 AM
  4. rear wheels
    By joe pain in forum Accessories
    Last Post: 02-05-2010, 11:42 PM
